The manual says 7.17 oz and then in parenthesis it say 2.12 cc or 5.97 Imp oz. None of those numbers equal each other, so which one do I use. The 2.12 cc is obviously not right cause that is hardly anything at all. So here I come to ask the gurus. Home much fork oil is about right? if it matters I am using ATF for the time being.
How Much Fork Oil
How Much Fork Oil
Theodore RooseveltTags: None -
.... that's 212 cc's; they put in a decimal point...
'78E original ownerFast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
Ok so I was trying to pull the forks apart and I cant get the allen bolt out. The internals of the fork just spin with the bolt. I put the spring back in hopping it would hold tension on the internals but it still just spins. Even compressed the fork with the spring in it and it still spins.Nathan
Theodore RooseveltComment
I did mine on the bike. I had to use a ratchet strap to compress the fork before it would come loose.Trapped in time. Surrounded by evil. Low on gas.
1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifierComment
Here's a link that should help.http://www.xs11.com/forum/showthread...tom+fork+tubesOk so I was trying to pull the forks apart and I cant get the allen bolt out. The internals of the fork just spin with the bolt. I put the spring back in hopping it would hold tension on the internals but it still just spins. Even compressed the fork with the spring in it and it still spins.BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
I had made a tool for rebuilding the forks on my wife's VMax a few years ago. Basically it was a 5/8" bolt welded into a 3 foot long tube with another 3/4" bolt welded in the other end. I think a 5/8" bolt has a 3/4" hex (about 19mm) which fit in the hex inside the fork tube (the hex in the fork had a lot of play for an 18mm so the 19 had a nice tight fit). That held the lower tube so you can pull the bolt out. The 3/4" bolt had a 15/16" hex (about 22mm) which fit the 91-up VMax forks so one tool could do every year up to '07. I built a few of them and sold three or four on ebay but interest dried up so I stopped. It's really easy to make. For the XS you'll need to try a few bolts until you get one that fits then weld it on to the tube. I used a magnet to lower the bolt in the tube to size it the first time until I realized the part number for the special fork tool listed in the Yamaha VMax manual actually had "18MM" and "22MM" in the part number. If you check the Yamaha manual for the XS I'm sure it's in there.Me Make Big Dings Wid Hamma N Welda
1985 VMX1200Comment
Hi Nate,Ok so I was trying to pull the forks apart and I cant get the allen bolt out. The internals of the fork just spin with the bolt. I put the spring back in hopping it would hold tension on the internals but it still just spins. Even compressed the fork with the spring in it and it still spins.
whizzing it out with an air wrench has always worked for me.
The fork tube's own inertia holds it from turning as fast as the air wrench can spin the bolt.
Stay with the 212cc metric volume, although the US and Imperial fluid ounces are different, I think Clymer's has screwed up their conversion.Last edited by fredintoon; 08-01-2010, 10:49 PM.Fred Hill, S'toon
"The Flying Pumpkin"Comment
