My ride is hard down
  • newc4
    • 606
    • Vienna VA
    We our Lexington VA ride did not turn out as expected. It was supposed to rain tomorrow! Anyway, my bike started missing then would clear, miss and so on. Eventually it got to a point where I could only accelerate very slowly, then it finally started fading. In a gas station I did the pipe spritz – 1-4 were cool indicating a bad coil. But as I pulled into a rest area it quit altogether. First thought, jumped cam chain. I get spark, even on the bad jugs so I’m not sure how to proceed. Need to get her home first. Then I can start trouble shooting the electrics. I guess you do a compression check for a jumped cam chain. Makes no odd noise otherwise.
    It's enough to make me say enough.
    Darrell
    78E
    80G project
    06FJR
  • petejw
    • 2269
    • sydney australia
    possibly be your pic up coils
    could have a broken wire, which would effect 1 and 4 also,
    usually if the cam chain has jumped a tooth or 2
    youll hear it,
    u can remove the left side timing cover and turn
    the engine over using a spanner, if you can rotate the engine freely
    you should be sweet on that part.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • MindWebs
      • May 2009
      • 431
      • Baldwin, WI
      pick-ups..
      i'd agree.
      not to costly, it's an easy "cheap" thing to try.
      good luck
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        If the engine was running normally when you started your trip it is likely electrical as others have concluded. 1 & 4 are shared electrically so check the pick up coil wires for breaks and or short out to the moving parts under the timing cover. If their good it may be a weak connection or faulty part between the pick ups and the coils. If you have good spark on all 4 when the bike is not in operation it is likely the pick ups.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • nutwister
          Xsive
          • Jul 2010
          • 38
          • Planet Earth
          + 1.....pickups.
            • 6762
            Darrell..sorry to hear 'bout this...I can relate to enough is enough...I've been there and then some too...but I still have the Max.
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              Start checking the connections for the pickups under the tank right behind the neck. I had a bad double female connector right there and it started acting up when it was wet, then finially had enough and stoped working all together.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
              • newc4
                • 606
                • Vienna VA
                Thanks for your responses. I got it home this afternoon. I'll start checking the electrics this week. I've all the parts for a DynaCoil upgrade so I'll finally do that. I've also have an extra pu mech so I should be able to swap out that easily. And I'll be sure to check out the wires on the neck.
                Darrell
                78E
                80G project
                06FJR
                  If it were me, I'd check the pickup coils and get that corrected first. Then change out the coils. If you change coils first, you might create a separate problem if its the pick up coils to begin with. Just my thoughts.
                  But I agree it would be pickup coil wire most likely.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    • Fort Myers, Florida
                    2nd
                    2nd that, good idea to fix first then upgrade, trobble shotting after install new stuff when not knowing what was wrong 1st can be a PITA!
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                    • newc4
                      • 606
                      • Vienna VA
                      That is my course of action. Replace the PUC and see if that fixes the problem. At least 2/3 coil should fire, 1/4 coil may be fried though it passes the ohm test.
                      Darrell
                      78E
                      80G project
                      06FJR
                        Remember that you don't have to replace the whole mechanism. Just the wires need to be spliced, to remove the old, weak wire.
