my xs1100 that i just put back togeather will fire but not stat running,we have fuel,spark and air??????and one out there that can help me out..email me at allen1978@live.com or on here...thanks alot
xs1100 not running
Did you foul the plugs?I had all three XS's do that last winter.I think I had bad gas or something.But even after I replaced the gas and cleaned all the plugs ,none of them would start, but would spit a cough and backfire.
I finally replaced the plugs on one and it fired right up.So I then replaced the plugs in the other two and they ran also.It was strange, but I have learned the hard way that sometimes you can't just clean the plugs.
I don't know if this could be your problem, but thought I would share my experience.80 SG XS1100
14 Victory Cross Country -
all plugs firing at the right time? Just put the bike back together, can the plug wires be on the wrong plugs? JOT
DanCurrent Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650Comment
I don't know what you all did that you had to put it back together but, if the ballast resister isn't hooked up, the bike will fire when it's cranking but then die when you release the starter button. Is that what it's doing?my xs1100 that i just put back together will fire but not stay running"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
XS1100 FrankenBIKE Build
Hey fellas. I have been a member since 05 but, up till now I have just looked at the gallery.
Here goes... I have accumulated 1 running (sorta) xs1100 and two part bikes. I was able to do some slight mods off and on over the last two years. I am finally ready to dig in and try to get a complete running chop bagger. I have some issues with the bike that runs (sorta). it seems to fall on its face in the middle rpm range and it kinda has a sputter put idle. I have never seen a running driving xs1100 before so I dont know what good is. I removed the carbs and rebuilt them. It ran a little better but not much. I think my vacuum advance system is suspect. I hope to have time to verify its operation using my newly acquired clymer manual.
I will try to take some pix soon to let you guys know how big this can of worms is. I hope to turn 3 bikes into two choppers.
later
P.S. I wish you luck fellow new guy.Comment
Without some additional info we are pretty much stabbing in the dark at the bikes problem. What type of work was done to create the "my XS1100 that I just put back together" situation? Was it running properly before the work was completed. Give us some additional info so we can help you out.
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
location might help. Sometimes if we are close enough members ride out to help.68 Honda Cl350 (sold)
76 Honda Cb 400 super sport
79 special (skull bike)
79 special (parts bike w/title)
79 special
80 standard full dress (Sat 24 years)
81 special (parts for now trying to get the title)
81 kaw 750 ltd (sold to brother-in-law)
80 650 maxim (fixing for wife)
81 650 maxim
81 Xs 650 special ( No title found in a barn)
88 Zx 600r (Sold)
01 Gz 250Comment
yes the bike was running just fine before,i was going to redo the bike from tire to tire but money ran short..i did nothing but take the bike apart and store it..then after assembly i have this problem..when you push the button it will crank over then fire up for just a second then die..the resistor is grounded good buth it looks cracked..i did a resistance test and it checked ok..it did sit for 3 years..new gas..cleaned carbs..and also what is a dimmer timer,4 wires and mounts towards the from of the bike..im in massillon,ohio...if you have any idea where to even start at please let me know..this bike was my dads(only the second owner)and after he died in 1994 i kept the bike and rode..now im getting depressed and ready to put it back in storage..i need help or a stick of dianamite....lolComment
-H. FordComment
[QUOTE=OHHHDEN;290232] - - - some issues with the bike that runs (sorta). it seems to fall on its face in the middle rpm range and it kinda has a sputter put idle. I have never seen a running driving xs1100 before so I don't know what good is. - - -
Hi 'Den,
if you can't scare yourself riding it, it ain't running right.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Hi Allen,
does it actually run for (say) 5 seconds or more after you take your thumb off the starter button?
Clean the carbs (Yes, again!)
Does it only run while the starter is cranking?
Check the ballast resistor.
Does it just fire pistol shots out of the exhaust as it's cranking?
Check that the rightside coil fires the outer cylinders and the leftside coil fires the inner cylinders.Last edited by fredintoon; 07-30-2010, 12:14 AM.Fred Hill, S'toon
my resistor fell off the frame (screw worked its way out)...and the bike died. actually, it blew a fuse. took me a day and a half to figure out what happened.....
change fuse, start bike.....idle and warm up.... as soon as i would lean the bike up......presto.....blow fuse and bike would stop. all lights would work, but no runny.
i H A T E electrical problems....'81H (my first XS ) "Grey Ghost"
4:1 Jardine w/ headerwrap
Windjammer(wiring issues)
New paint/brakes to come!!
'80G FrankenBike (parts bike)
'80G to fix "BlackSunshine"
Stock Pilots/125 mains
Pod filters; 4:1 Kerker??
SS Brake lines w/ new M/C's
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Comment
