Interesting discussion !
Assuming (I know, I know) that the valve length is approx. 3 1/4" and using the expansion rate of mild steel along with a conservative estimated temperature change of 350 degrees from room temperature to hot operating temperature, the valve stem will expand in length .0006" or .015mm. That is three shim sizes since they are supposed to be in increments of .005mm. And maybe it is overkill but the hot gap is more to consider than just valve stem expansion. You would also need to consider expansion of the cylinder head, which is hard to measure but being aluminum with a higher coefficient of expansion than steel is probably more than negligable. Also, expansion of the cam lobe, while negligable, contributes and then there is the actual remaining oil film between the lobe and the shim. So, if you are very, very tight on clearance at room temp it is easy to see your clearance can be reduced significantly at operating temperature causing a possible host of problems on a street motor.
When we used to race Super Stock we would keep our valve clearances on the tight side but then, operation was only approximately 2 1/2 minutes per run total, including the drive time up through the staging lanes. But then, we were checking our valves gaps often and adjusting valves on a HEMI motor is actually alot easier than our Eleven motors.
So, on a street motor I would stick somewhere in the middle of the range and not have to worry about it until a check at tune-up time.
I just replaced the cam chain tensioner so I know the noise that makes. I also just changed the oil and filter and found no flakes.
