new owner, any way to adjust very high idle?
  • dschmitta
    • Jul 2010
    • 174
    • Altoona,PA
    Hey everyone,
    I just bought bike two days ago. It looks and runs awesome. Anyway, after running for a minute or two, the idle jumps up to around 2,300 rpm's and will not go down. It idles right around a grand at first and then jumps. Is there an adjustment I can try? Didn't come with owners manual or anything. I found a link on one of our threads last night, but the the download tells me files are damaged. Also, if anyone could help, trying to figure out turn signals, whether I'm using wrong or prob. Sometinmes when I go to use, the light stays on steady. After moving lever back(without cancelling)and trying again, they work. I also do not understand auto cancel feature? Any help greatly appreciated. By the way, its an xs11,sorry
    Last edited by dschmitta; 07-23-2010, 09:42 PM. Reason: forgot to mention model of bike
    1980 xs1100g
  • mro
    • 4276
    • Hayward, California
    78 and 79 models (BS34 II carbs) have the idle adjustment knob between carb two and three, rear of carbs near the top of them.
    81 to 82 models (BS34 III carbs) have the knob between carb two and three, bottom rear.
    High idle after it warms up a little points to needing to sync the carbs
    mro
    BTW
    welcome to CH 11 ... have any pics of your XS?
    • mro
      • 4276
      Turn signals
      Clean the wire connectors.
      XSpecially the grounds on the rear turn signals.
      Rare but sometimes the light bulb socket gets corroded and needs to be cleaned too.
      mro
      Take a look thru the tech tips.
      Most all the answers for known problems are there
      • dschmitta
        • Jul 2010
        • 174
        • Altoona,PA
        Hey, thanks for info. I do have a pic or two saved, just can't figure out how to attach?
        1980 xs1100g
        • dschmitta
          • Jul 2010
          • 174
          • Altoona,PA
          mro
          Thanks for help. Love the bike, just gotta get used to it. Shouldn't be that bad. I upgraded from 77 CB750 and it had it's quirks.
          1980 xs1100g
          • mro
            • 4276
            Pic info maybe in the tech tip section too. I've herd it's here somewhere
            Need a pic host site. I use photobucket.com (free site)
            After you up load your pics to there site, copy the "IMG" tag.
            Past that tag in your post here.
            results in something like this
            mro
            • dschmitta
              • Jul 2010
              • 174
              • Altoona,PA
              mro
              Thanks! I'll get a pic on.
              1980 xs1100g
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                • Fort Myers, Florida
                Mro
                Nice bike, it is like a 79 midnight, kinda, as they never made a midnight in79, is looks great!
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • XS1100_OEM4ME
                  • Mar 2009
                  • 1619
                  Welcome
                  Originally posted by dschmitta
                  Hey everyone,
                  If it runs at 1100 when started, then after warm up 2000+, it is your carb's out of adj. got to be a bitch to shift to first, "clink"! Sync. the carb's and then turn down idle to 1100 rpm before riding/clunking the trans.
                  1980 XS1100 Special
                  1990 V Max
                  1982 KZ750 LTD Twin
                  1974 CB750-Four
                  Past/pres Car's
                  • dschmitta
                    • Jul 2010
                    • 174
                    • Altoona,PA
                    carb sync and idle reply
                    Thanks for info. Will do. Let ya know what happens.
                    1980 xs1100g
                      Hi dschmitta and welcome,
                      about how the signals should work:-
                      The thumbswitch is spring-loaded to return to the centre position. To turn the signal off again, push the switch straight in from the central position.
                      The self-canceller works by getting a signal from a reed switch in the speedo that counts a certain number of times the speedo drive turns then switches the flasher off.
                      The only flasher that will work with the self canceller is the appallingly expensive ($80+!!!) stock unit. The stock unit will only work if it's driving at least 2 x 27Watt bulbs. Higher loads flash it faster, lesser loads (say you subbed in 22W bulbs) and the signals just stay on steady.
                      You can swap in a $10 electronic 2-pin flasher and lower wattage bulbs will work fine but you lose the self-cancelling feature.
                      Before you get medieval on the system, clean every contact, connection and switch in it.
