Rotors
If you are talking about small groves, that is just cosmetic, no warp or pulse, save you $ IMHO
... what? Im not sure what a clutch holder is but what ever it is, its not needed to fully pull these clutches apart. Depending on how bad your clutch slip was and how long, your steels may be glazed a little. Not a big problem, and if the new springs fix everything then thats great, no need to do anything more than ride it. Generally, once your at the point where the springs are comming, your ten minutes away from having the entire clutch out...and usually people will take some 220 grit paper to the steels to clean the varnish/glaze off them and make sure the frictions are in spec... Hope your problem is solved! Ride safe.
