I don't like doing it, but since I can't physically wrench on the bike anymore I am forced to take it to a local shop. (Good guy & only one I trust). The first time the carbs ever needed cleaned (since I bought it new) was 3 years ago and this guy did a good job. Now after experiencing similar symptoms -- low RPM lugging, back firing while decel, and rough idling-- he has been thru the carbs multiple times and it's still lugging.
We've been thru all the steps in the help section (this guy works on carbs almost exclusively and he was impressed with web site) and while the decel backfiring is gone, when going from 2 to 2.5K RPM with a healthy amount of throttle the missing is STILL there. Also it idles fine at times, and misses at other times while idling. If the choke is pulled out one click the idle rpm goes way up but the missing at low RPM problem is gone. Also, if I stay out of the throttle and accellerate slowly the missing doesn't happen.
The engine/carbs/air intake is stock except the 4 into 2 Jardines. Rejetting was not needed for the exhaust change.
The choke "fix" tells me it's a lean problem but after many hours and way too much expense it's still a mystery. After 33 years of happy marriage, divorce is looking better and better. I spend a lot of time between 2 & 4K RPM and know after all these years how good it can pull. this flat spot is making me crazy.
