I got 2500km on Blue balls now, the bike runs perfect..
But, I got that annoying detonation thing going on between 3500 - 4000rpm.
Unhooked the vacuum line to the advance for a test run, noise is gone ..
I am running the stock vacuum advance right now, base timing is set 5 degrees.
I was lucky enuff to get a brand new service bulletin replacement vacuum advance a while back ( by accident ) part # 3H5-81683-09-00 as described in Yamaha's TSB from a local ma and pa dealer, box was dusty, and probably sitting in their stock for 30 years, lol .. ..
.jpg)
Here is the difference between the factory installed VA and the TSB replacement part.
At rest, they both have the same arm length ( I measured from base of the advance to the hole in the arm ) 44.85 mm
[IMG]
[/IMG]
The stock advance comes in full at the 5.9 in/hg with a travel of 7.62 mm
The TSB part comes in full at 3.8 in/hg with a travel of 2.79 mm
pic shows the difference in arm travel at full vacuum.
.jpg)
So there is the difference between the 2 parts ..
I haven't tried the TSB part, but am gonna swap it out after dinner and go for a test run .. will report back ..
.jpg)
[IMG]
[/IMG]The stock advance comes in full at the 5.9 in/hg with a travel of 7.62 mm
.jpg)
