Lights out
  • jaimes-duran
    • Oct 2009
    • 44
    • Wake Forest, NC
    Lights out
    Hi everyone. I've searched the threads and it's probably there but I just can't find the answer. I'm more of a motor type of guy but when it comes to electrical I'm lost. Heres the problem I got caught in the rain and now when driving mostly on rough terrain my lights will go out(speedo cluster and headlight) not the turn signals. I would guess its a loose wire but please tell me where to start! Thanks
  • nutwister
    Xsive
    • Jul 2010
    • 38
    • Planet Earth
    First place I would check is all the plugs behind the headlight. Remove the headlight from the bucket and you'll see what I mean.
    Everything comes together in there.
    • Rickrod3
      • Jun 2009
      • 721
      • Oakland, New Jersey
      Fuse box
      If you have the original fuse box I would check it or better yet replace it.
      When I was putting mine back on the road it gave me a lot of intermintent problems.
      The head light relay would be the next area.
      I had to replace the female terminals in the plug. The resistance in the dirty terminals was so high it would blow the head light fuse.
      With a wiring diagram you can check the circuit out step by step.
      HTH
      Rick
      650SF
      XS1100SG Project bike
      • jaimes-duran
        • Oct 2009
        • 44
        • Wake Forest, NC
        thanks guy yes my bike is completely stock (besides no paint) and it amazes me how mint everything is. It's like it was in a capsule for 30 years. I've never had a problem from the signal lights down to that infamous octy! It's sad how a rain can ruin that joy. But I will check those out.
        • nutwister
          Xsive
          • Jul 2010
          • 38
          • Planet Earth
          I personally don't believe that the fuse box is the problem in this situation because the fuse that runs the dash lights also runs the starter solenoid and the ignition.
          If it was a fuse it wouldn't turn over or run......BTDT
          IMHO
          • ntrthamatrix
            • Jul 2010
            • 4
            Fuses
            I have a 1980 XS1100 Special, the fuse box's are the achilles heal for XS11. I too had the same problem, I replaced the fuse box and it has been solid since.
            Here is a link that I followed
            I bought the fuse box from here
            WiringProducts is the online place to buy automotive wiring & electrical supplies. Many of our wiring products are made in the USA. We stock thousands of electrical parts such as wire, electrical supplies, automotive wire, fuse blocks, battery cable, wire terminals, automotive electrical, circuit breakers, wire looms.
            What happens is the old ones loosen up and move around or don’t make a tight enough contact. When mine failed the fuse had black spots all over the end that was loose. It also made the fuse and connecting wire very hot because of that.
            I would inspect them closely and see if there is any movement in there.
              • 1376
              Lost in the Maze of Connectors/Wires???
              Being lost is where everyone begins with electrical problems. Now is as good a time as any to look at the "map" and get familiar with the roads that electrons follow:
              Diagram Courtesy of TopCatGr58
              (click on the diagram to make it big enough to be usable...)
              If you look at the diagram you'll see that the headlight and the cluster gauges share a ground and something else: the left handlebar switch. As the switch is more open/exposed and vulnerable to "precipitation" I'd check the wires going to/from that switch and yes, pull the switch off and take a peek inside.
              The best troubleshooting equipment is built right into your face. Follow the flow or the lack of flow of electrons through the wires. Using your eyes and a diagram for your specific model/year is a good way to keep from getting lost.
              • benxs1100
                • 92
                • Somerset, Pa
                I had the exact same symptoms. Headlight and guages quit working but turn signals still worked. I had a corroded connection behind the factory fuse panel. A little cleaning and it has been going strong since.
                '79 XS11 Special
                MikeXS Pods
                Green Coils
                  Ditch the old glass fuses!
                    Agreed! It might not be the problem THIS time, but you're just asking for trouble by keeping that old fuse block. TC sells the whole thing, including connectors for $11, IIRC. Check out the sticky in the Parts For Sale section.
