Pilot Settings? 78 Carbs
  • coltrain5000
    • Mar 2010
    • 34
    • Ashburn VA
    Hey Guys, was hoping to get a little input as to where everybody is at with turns on the pilot screws. I dont have a colortune.. yet. I'm not having very good luck going by ear and highest RPM method for each carb. I have searched and researched so I know stock settings are about 1.25 turns out and adjust from there. I'd like to know in general where I would be at considering my 78 carbs and drilled airbox..(more details in sig) I have mine out 2 full turns and it seems pretty good. Just a tad rich maybe? .. Plugs dont say, but the low end power is what I am judging. I went to 1.75 turns and power seemed to be down.
    Thanks!!
    1978 Macho Maroon XS1100 Mikesxs green coils, ZRX Carbs, spaghetti jardine 4 into 2
    1989 FXLR harley that is not stock
    1977 RD400 stage 2 ported with VM30 carbs
    1975 RD350 modified
    I can't leave anything alone
    Every engine is different, the compression and the exhaust, the air inlets, condition of carbs, all play a part in that setting. So setting yours the same as someone elses will not do you any better than where you are at since it seems to be running decent or well where you are.
    Check plug color after a couple hundred miles and see where your at. if the lugs look nice and tan color, and your idle seems smooth and level. Thats the best indicator really.
    • mro
      • 4276
      • Hayward, California
      The 1 1/4 out is a starting point for a stock XS.
      Tuning by ear is easiest if you can get it to idle around 850/900 rpm
      which makes it easier to detect any change.
      mro
      • coltrain5000
        • Mar 2010
        • 34
        • Ashburn VA
        Thanks for the input...
        Is each screw all over the place or are they generally about the same turns out? I suppose I will get on that color tune product and purchase.. Just hoping to get some general settings of other similar setups is all.
        Thanks for the advice.
        1975 RD350 modified
          They are generally all similar on one bike, but 1/16th of a turn makes a difference, and as DG said, no 2 engines are the same, and no 2 carbs are the same. You may have one at 1.75, and another at 2.25.
            Yes, IMO, if you have any one screw more than one turn different than another, something is not correct. Now, if compression is off in that cylinder that can also cause it.
            But it is not uncommon for noen of them to be exactly the same and off by a half to full turn I would not worry about.
            • petejw
              • 2269
              • sydney australia
              the mixture screw settings
              should all be close to each other,
              if there not, then more than likely
              the float levels arent set exact to each other.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
