OK. Here's what really happened. Fired it up, backed out of the garage. Rolled across the driveway. Smooth, asphalt surface. I'm running a 850 FD. Going 3-4 mph, hit a full roll-on, bike took off way strong. Let loose the throttle, felt a thump when the front wheel hit the ground. Wasn't a high wheelie, but it did lift off the ground.
I don't do it on purpose, but if I wanted to, I'm certain it would get lift in at least 2 gears whenever. Never had this kind of low-end torque before the valve change in 30,000 miles of riding.
I have new clutch frictions that arrived today so once those are in I may be able to do it on the 78 as well..
Hope nobody takes that the wrong way.
