How much oil is too much oil?
  • Incubus
    • 1003
    • Austin TX
    I installed an oil cooler on my XS today. I wasn't sure how much oil to add with the additional volume in the system created by the oil cooler, so to make sure I didn't run with insufficient oil I put in an extra quart. Now, when I first shut off the bike, the oil level is right at the full line in the magic window. After the bike sits for a while the oil just reaches the top of the window.
    Do I need to drain a little? Or will any excess oil blow out through the crankcase vent?
    Thanks.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • dbeardslee
    • 4385
    • Maineville, OH
    As long as you can still see the top of the oil level through the window you should be fine.
      MY thought though is that with the oil cooler being higher than the crank case and not really having anything stopping the oil from running out of the cooler wouldnt all the oil in the cooler then just dump right back into the crank case and then making it look as though the bike has too much oil when really it does not have too much?
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        It might be possible, depends how you plumbed it in...
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • Incubus
          • 1003
          • Austin TX
          I thought of that as well, Nate. The oil is attached the the frame crossbar and it has the adapter plate above the oil filter. It has no thermostat of anything holding the oil in the cooler when I shut it off.
          I would love to find a thermostat that I could plumb in line with the cooler so I not worry about bypassing it during the winter. I ride year round, including those frigid days in January when the temp only gets into the 60s or 70s.
          Anyone know of a thermostat that would work?
          Patrick
          1969 Yamaha DT1B
          • Rstyduck
            • 107
            Patrick
            60's or 70's? Lol, I thought you said winter. Lmao.
            Ive ridden in -40. Always go out for a new years ride.
            Snow doesnt bother me much.
            Had a 71 XS650 Hardtail that i used to run to work every day years ago, about 35 miles one way. Didnt matter the weather or temp, gotta get to work. No car.
              Hey Patrick,
              I,too, don't think you have too much, and once the engine is running, the extra is being circulated into the cooler and lines, and so the level in the sump/pan is most likely very close to OEM when running, don't think you'll have any blowing out the overflow vent.
              Thermostat:
              B&M
              Thermostat valve 70259
              Or...
              (562) 404-0488 info@usmotorworks.com
              Part 13011 fluid control thermostat kit
              Opens at 180 degrees, with 3/8" barb fittings, etc.!
              • scott0757
                • Jun 2007
                • 130
                • Syracuse, NY
                Oil Cooler Adapter
                My oil cooler adapter plate (goes between the cases and the filter housing) has a check valve in it to keep oil from back flowing. In fact when I change the oil, I have to push up the check valve to get the air seal broken to drain the cooler.
                Past Rides:
                1969 OSSA 250 Pioneer
                1979 XS650 Special
                1978 Honda CB750K
                Current: 1980 XS1100SG
                • dentat2
                  • Aug 2009
                  • 36
                  • Granite City, IL USA
                  If you had to much oil in it, it would come out the vent. i found this out the hard way this year, i went for a ride after having it in the garage for a few weeks. before we left i added some oil and aparently didnt look close enuff or looked at the window wrong but there was to much. 2 blocks later i made a right hand turn and the back side slide out some and i thought maybe my tire was going down. i checked the air and it was fine. later on in the ride after it slid around a few more times i finally noticed oil in my treads on the tire and after a little investigating seen that my vent hose was hanging near my rear tire. after repositioning it i havent had anymore problems.
                  81 Support Your Local Illinois Nomads 81
