Help!! mid range carb issue
  • indy400
    • Feb 2010
    • 5
    • Wahpeton North Dakota
    I have a 78 xs11. I am using a uni brand air filter (new). The problem is when I ride it and open it up at 2500 RPM it will reach 4000 RPM and studder the engine wont gain more RPM. Now if I stop take off the bottom of the airbox with the filter. The thing will take off like a cat shot in the butt with a BB gun.
    The carbs have 142.5 pilots 145 mains needle clip middle slot.
    The exhaust is stock head pipes with HD Dyna Glide mufflers.
    If anyone is running HD mufflers please post/reply with the jets and needle clip position you are running and type of airfilter. I have been wrestling with this problem since the begining of spring. This is my first xs1100 but, I have owned and repaired countless bikes. I have never ran into this type of problem before.
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Welcome to the site...
    With the information you have given its too hard to point our fingers at one single reason. So, here come the questions...
    Do you have UNI Pods or are you using the stock air box? You said filter and not filters so I will assume your using the stock air box...
    I assume you made a tyop and your pilots are 42.5 and not 145.5...anycase, why are you running these size jets?
    Stock for the 78 had 45 pilots and 137.5 mains. The only reason to change those are if your have made considerable changes to the air box or the exhaust...
    Also, when is the last time you cleaned the carbs and how through of a job did you do?
    Take a look at the tech tips for carb cleaning and you might notice a few things that come apart that you missed..?
    Just adding the HD mufflers alone do not warrent the changes made to the jet sizes. I cant think of any reason you would have to go larger than 140 mains with your setup.
    What color are your plugs, are they showing a rich condition? Taking off the bottom of the air box kinda proves that the engine needs more air and less fuel. IMO you need to try some 137.5 mains, first check your plug color to verify its too rich...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • dbeardslee
      • 4385
      • Maineville, OH
      If you pull the air box and it runs right, it's an indication that your jetting is too fat, like Marshy said. I've seen them hit a wall in the 4-5k range from being over-rich. You could either drop back down on your jet size, or open up the intake. A free flowing filter and drilled air box might put you in the correct range. If you don't have a colortune plug, now would be a good time to get one - they come in very handy when trying to get your jetting right. JAT
      • petejw
        • 2269
        • sydney australia
        as the others have said,
        sounds like your running rich,
        make sure you havent got any restrictions
        in the air box or snorkel,
        also make sure the carb vent hoses arent blocked or restricted,
        check your float heights arent to rich and you could drop the
        size of you main jets back to stock,
        youll need to clean your spark plugs
        if theyve been fouled.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • indy400
          • Feb 2010
          • 5
          Carb issues
          Thank you all you have been very informative. I will be trying you advice this weekend. I will post after that to let you guys know what happened. Until then I will just have to commute on my 76' xs650 hard tail bobber. You guys all keep the rubber side down.
          • MindWebs
            • May 2009
            • 431
            • Baldwin, WI
            here is what i had to do to cure some of my issues..
            How to make HD pipes work on a xs1100.doc
            no... i'm not done yet so don't ask about jetting...
            i'm still fine tuning that.
            • tadtl1
              • Mar 2010
              • 98
              • Auburn Mi
              Hd muffs and Pods
              Hi
              On my MNS with the late carbs I am using the standard 110s and the 42.5 pilots, these are what are stock with the bike. The needle is non adjustable. I do have a very high rpm burple at 7000 rpm, but I only ran it at that speed as a test, never get there other wise, you know, getting old. The muffs are the sportys smaller ones, 19 inches long, and pictured in the above download for jetting sportys muffs . The pods are the emgo cheapo brand that I got from Georgefix. I didnt have any luck with easily removing my air box, so I set it aside and George concurred that the pods eliminate all the effort, now I can take the carbs off in ten minutes flat if I need to.
              80 MNS , Georgefix pods , crossed fuel lines, no octy, inline filters, Daytona handlebar, custom seat, Hardley 19 muffs
              • planedick
                • Mar 2005
                • 2068
                • Yorba Linda, California
                Carbs off
                I am about to make a movie that shows how to remove and install the carbs with the airbox, probably in 10 mins or less.
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                Custom security system
                Stainless braid brake lines
                  That I want to see.
                    Originally posted by natemoen
                    That I want to see.
                    Ditto. I would be interested in seeing this. A number of years back when I was heavy in to the carb removal/carb install phase, I was getting pretty good, but I don't think I ever got to 10 minutes. Heck, it takes me that long to get the necessary tools ready for action!
                    The pressure is on!
