The fuel gauge has quit. Have determined it to be the V reg. at the underside of tach (black box filled with epoxy resin or whatever). It gives no volt out, but gets about 11 V in (key turn on, engine not running). I plan to make a new regulator by using a LM317T or similar. The Q is: Do you need a resistor in the circuit to limit the current when tank is full and hence the resistance in the fuel level sender is close to 0 ohm? Otherwise I would expect to short-circuit the whole thing....?
What is the current flow in the circuit when the tank is full?
Is there a circuit drawing of this arrangement available?
cheers!
cheers!
. It's one of those things that while annoying, is not a real problem since I know when it's getting low by the number of miles I've gone anyways. I figure that unless the engineers who designed things were idiots, it was designed without need current limiting, that would be a bit silly in this type of gauge.
