1979 XS Special (w/octy)
This will probably be a quick one. I replace my battery last week, and when I did, I started the bike to make sure I could take it to work the next day. It started just fine, like last season. The next morning I had a pool of gas under the bike. A colleague at work suggested the floats, but I had never had such a problem. I could not immediately find the leak, but when I pulled the tank up, just a little, two of the fuel lines pulled off the "T's".
Thinking this was the problem, I replaced my fuel lines, one of which had a hole where the hose clamp when through the line. I replaced all of the lines. The bike started immediately. The next day, it barely started, and stall when I gave it gas. When I would tip it far to the right, it would start and idle, but stall if I gave it gas. Now it won't start at all.
Did I connect the lines to the wrong petcock nipples? Does the "T" from the Octy and petcock have a flow path or valve to make it one way? Do I not have enough gas in the tank to feed the bike - perhaps a gallon or less.
If, and only IF, I take out the octy, what do I do about the vacuum line from the octy to the #2 carb. Do I cap it at the carb?
Any other thoughts about why it may be gas starved?
