xs weak front brakes but good flow?
  • klrconcours
    • 28
    • duluth mn
    Can it be, despite pumping a full pint through both bleeders with no sign of air I still have air in the line Up high? I love this 81 XS too much to total it and me! Lots of flow when bleeding, just have about 40% stopping power. Good pads, clean rotors...The bike was resurrected from 6 years storage. I did a thorough caliper clean and check tho.
    klr650 thumper
    '75 carbon fiber naked gold wing
    Proud new owner 81 Eleven Special (all time fave!)
    Formers: 81 Kawi LTD 1000
    '79 CB750F, '98 Kawi Connie
    Did you clean and check the master cylinder? They get plenty dirty up inside there as well.
      I had the same problem and I let it sit and the next day oddly I had pressure. Same with the back. So try letting it sit for a day or so and then go back and give it a squeeze and see what its like.
        There is an "old" trick that Prom explained once upon a time. He learned it form some old guys, cause he it to your for all that.
        If you think it is air stuck, then take a bungee cord or the like and tie the brake lever squeezed in about 2/3 of a pull or so. Turn the handlebars so the reservior is the highpoint of the system. Now let it sit like that overnight. Try the brakes in the morning. It has made a difference on mine more than once.
          Hey KLR,
          Yep, due to the position of the MC vs. the very low calipers, air can get trapped in the junctions and such. The handlebar lever squeeze trick is to get the piston passed the spooge hole, and so any residual air near the MC will eventually bleed/float up back into the reservoir.
          IF you don't like waiting, then take the calipers OFF the forks, wedge a piece of solid wood or something same or thicker than the rotors into the pad spaces, and position them at or above the height of the MC, and then with a HELPER, bleed them again, and you may finally see the air flow out of the bleeder valve. Tapping on the MC and hoses and junctions may also help loosen the bubbles and get them flowing down/up the line!? YMMV
          • klrconcours
            • 28
            • duluth mn
            THANKS! That 2/3 pull and bubbles away makes great sense! Gonna run down to the garage and get it set up! BTW there is pressure, just a firm squeezy and poor stoppy.
            klr650 thumper
              Okay, did you do a rebuild of the calipers, or are you just doing a bleed??
              The old calipers can get corroded, gummed up, the piston can almost get frozen, and so you can get pressure, but it doesn't actually MOVE to compress/squeeze the rotors, and so poor braking!?
              Also, the special pads look funky...slanted, that's OEM design! Did you take the calipers off and inspect the pads for glazing, fluid contamination, etc.!?
              The calipers can often be rebuilt WITHOUT replacing the square shaped O-ring, just cleaning it out, scraping the corrosion out from the groove the O-ring sits in, etc., and then reassembled with brake fluid, and the piston will then be more free to move under the brake lever pressure! JAT.
              • jmnjrpa
                • Jun 2009
                • 863
                • Lewisville, Texas
                Ss
                Stainless Steel brake lines. If you find no air and don't have them yet you will not believe the difference! I think the old rubber lines tend to expand way too much. JAT
                '81 1100 MNS - "Midnight XSpress"
                Original except:
                Big John
                • 79XS11F
                  • 3563
                  • Ottawa, Ont. Canada
                  I have had this issue as well and got the air out by removing the calipers from the forks and bleeding them with only a thin board between the pucks to keep the piston from being dislodged from the caliper. Once the calipers are real full of fluid from bleeding I use a large C clamp to push the pistons back all the way into their bores. this forces the fluid up the lines and flushes air out through the mc. Just don't over flow the mc. I used a syringe to remove fluid as it was returned to the mc.
                  Rob
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
                  • petejw
                    • 2269
                    • sydney australia
                    u could try bleeding the master cylinder,
                    wrap a rag around the banjo nut so not to spray
                    brake fluid every where, crack the bango nut at the mc
                    and slowly depress the lever see if any air comes out.
                    also dont forget to check the levers free play, this can
                    also make a big difference.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • klrconcours
                      • 28
                      • duluth mn
                      Well, what I tried (5 posts up, the bungie and over night trick) didn't do it. On to try a couple of these other tips posted. Thanks. We'll see. Oh, and yes I took the calipers appart and put them back together now clean as new.
                      klr650 thumper
                        I'll ask only because it is so important and you did not specifically say it, did you pull out the rubber o-ring type seal in the caliper and get all the schtuff down in behind there out? Ddi you pull the master cylinder apart and clean everything in there?
                        • klrconcours
                          • 28
                          • duluth mn
                          Calipers yes. Totally like new. Master, Partially. Gonna take the whole enchilada appart today. I guess I was being lazy since it pumps copious fluid We'll see.
                          klr650 thumper
                          • klrconcours
                            • 28
                            • duluth mn
                            Master clean as new now. All rubber great shape too. Same problem. Humph! Thanks tho!
                            klr650 thumper
                            • 81xsproject
                              • 3185
                              • Fortuna, CA
                              Are you both calipers at the same time? Switch back and forth between calipers. I have had luck removing the master from the bars and pumping fluid through with it in various position (but keep fluid over the intake holes or you'll just push more air in).
                              '81 XS1100 SH
                              Sep. 12th 2015
                              RIP
