Does it realy make that much defference to put solid mounts on the motor, got the motor out of the bike that i am going to put in another bike and if I was to change the mounts, now would be the time to do it, the stock ruber mounts look to be in good shape.
Solid motor mounts
Solid motor mounts
1979 xs1100 f
142 main, 45 pilot, Jardeen crosover 4/2, no air box
floats @ 25.7
1979 xs1100 F
1978 gl 1000 goldwing
1981 gl 1100 goldwing
!986 venture royale 1300
Just an ol long haired country boy, come to town to spend some egg money
when ya get bucked off, get back onTags: None -
Use the rubber mounts Bob.
The vibration with solid mounts will numb you right down to your tail bone.
I've never gone rigid mounts on a bike or car, but I have done solid rubber motor mounts versus grease filled rubber mounts. BIG difference in vibration. I imagine the solid mounts will be quite noticeable.Corey J. Bennett
'79 XS1100SFComment
1979 xs1100 f
floats @ 25.7
1979 xs1100 F
when ya get bucked off, get back onComment
The PO put aluminum motor mounts on my 1978 and IMO they do make a difference but still as smooth as the rubber motor mounts. I haven't noticed any difference in vibration.Last edited by mstic2000; 07-01-2010, 09:50 PM.Comment
i made urethane mounts for mine http://s88.photobucket.com/albums/k168/mxmikie/careful what you wish for.........you might get itComment
1979 xs1100 f
floats @ 25.7
1979 xs1100 F
So what is your opinion of before and after the poly bushings?i made urethane mounts for mine http://s88.photobucket.com/albums/k168/mxmikie/Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example"Comment
Did you pour these, modify something existing, or machine them from round stock? Do you know what the durometer of these were?i made urethane mounts for mine http://s88.photobucket.com/albums/k168/mxmikie/
While I don't think solid mounts would be a great idea, I can see urethane as an improvement...
'78E original ownerFast, Cheap, Reliable... Pick any two
the hardness was 70 i made a bunch of sets i sold some on the brit board i did a write up and posted it here but nobody here wanted them i make a lot of replacement motor mounts and suspension bushings for all kinds of cars that the parts are not available i turned down an existing bushing with a 3m scotch pad to fit and reused the insert i sold sets of 6 mounts for $65.00Last edited by mxmikie; 07-02-2010, 11:44 PM.careful what you wish for.........you might get itComment
