reading spark plugs
  • reading spark plugs
    hello again Gentlemen,
    I pulled the plugs just to check whats going on in there, and checked with the NGK web site. #1 is definatly rich, #2 and #3 look like the "Dry fouling" picture on the site. #4 is dead on where it should be. What causes dry fouling? Acording to the site it has something to do with plug wires. How do i test and fix whatever is causing this?
    Thanks again!
    Tony
    78 xs11 aftermarket 4-2 HD mufflers, whats left of it is stock. A work in progress for sure.
    searches will bring stuff up.
    here is a good thread for ya
    http://www.xs11.com/forum/showthread...hlight=reading
    Good luck!
    Webs
    1981 Yamaha XJ750RH Seca (War Pig) XS11S front end and rear swingarm with 17" rim, 20mm ammo box saddle boxes, HID headlight, LED aux lights, Heated grips & seat, Bark busters, Harley 12" shocks, S.S. brake lines, oil cooler
    PW50, PW80, YZ80(mine? what the??? Brrap OH...)
      Plug wires
      Are solid core on the stock coils.
      The plug cap screws on and is a resistor cap.
      Not unusual for the end of the plug wire to get some corrosion which you can trim off 1/4 to 1/2 inch, clean the cap and screw it back on.
      mro
      BTW, info might be in the tech tips
