Can someone enlighten me as to my delema.I have a 80 SG that would ping under full throttle . would only do this at wot. So in the process of some other unrelated work ,I decided to pull carbs off to see what was going on.supposidly these were prof cleaned and such.I don't think this happened.carbs looked like never been off that I could tell.screws so tight I thouhgt I was going to break them.but after much aggrivation Igot carbs apart. now according to my manuel I should have 110 main jet in #1&4 and 120 in #2&3 .NOT. Has 110 in all 4 carbs. insides were dirty too. checked floats don't think they are right either.book says .906 e.i. 29/32 on my pocket ruler.I come up with about 25/32. and floats vary in hieght.could all this be causing my problem with pinging. bike does run good .where is a good place to measure floats to get good readings. and do I need to get 120 main jets for #2&3 carbs.some of you carb gurus any help would be great. Tired of bike pinging at wot.not good on engine.also idle mix screws still sealed . do i need to unseal them and readjust. bike is stock except for uni air filter and dyna coils. And I suppose I'll have to re syc carbs to. thanks to all who reply.
