I am the new owner, and new member here and am having a problem with the 1979 Yamaha XS1100 I bought from PO, I know the petcocks(2) are vacuum,I need to know where to leave the handle at. prime, reserve,or on I belive it should be to the on position all the time(save times that I have to prime carbs, or low on fuel. The XS I got was sort of a barn find with only 16000 miles on clock (was last taged in 94),put battery in her started her up, filled with petro and rode her home (81 miles)ran really good up to 70mph then started bogging down,did get her up to 90 at one time. PO put straight pipes on. Will be changing oil/filter,new cone fuel filters, and dumping a can of sea foam(will put 2oz of sea foam in crankcase before changing oil& running about 10-15 miles) in gas tank t
hen running tell amost empty (has just shy of half tank now) whatya think? any suggestions are welcome. thanks the newbe
You are correct about the petcocks. "On" is the proper setting, and the vacuum from the engine is what allows the fuel to start flowing (unless the vacuum diaphragm springs a leak). "Prime" bypasses the vacuum for when you are tuning things, or right after you have cleaned the carbs (and they are empty).
(Can't recall if it was a fuel or electrical problem which was the source of the fire...)
