ok guys, after getting a few miles on her, I've got a couple more issues.
1) I'm pretty sure my starter clutch is really taking a crap on me. It starts just fine but i dont think its letting go once the engine is started. Once and awhile when i shut the bike off i can hear the clutch spinning for a second. I've got another clutch sitting on the shelf but I just got on the road, and i dont really want to tear the thing apart again. So question here is, will this do any harm other than just burning up the starter clutch? could i give it a shot of gear oil or anti seize as a band aid?
2) When its cold with the enricher pulled out the engine will start to idol up then randomly pop out of carb #2 and nearly kill the idol.
3) pipes 1 & 2 seem to run colder than 3 & 4.
4) When i wind up the engine it takes a few seconds for the engine to idol back down. I know the throttle isnt sticking but other than that I have no idea here
5) once up to temp and under load the low end power isn't there anymore...
If it helps she seemed to run better, idol and mid-top end with less back pressure before i put the HD mufflers on.
Sorry for the long thread but this is the first year I've had her out on the road for any amount of time, and its my first bike
Thanks again guys, you've been life savers
Tony
Tony
The starter clutch pinch rollers could be binding and so not releasing their grip once the engine is started!?
Fixing it involves splitting the cases...not my idea of fun! I didn't look/check to see what model/year your bike is, so I don't know if you have the kick starter? I was going to suggest removing the starter motor and then either kick or push start the bike, and then observe the starter motor to clutch gear to see if you can see it continuing to spin...it's not supposed to keep spinning IF the clutch is releasing it's grip on the crank after starting.
