blind plugs on the intake adapters splitting
  • meteor3178
    • Dec 2006
    • 22
    • San Marcos, TX
    I was wondering if anyone had a substitute for the blind plugs found on MikesXS. I seem to have to replace these buggers on a regular basis because they split. I just installed 4 new ones about three weeks ago and TWO have already split!!! I usually fill the split with High temp RTV but just the same it is irritating to have to repair this things so often. If I don't then I run lean on that cylinder.
    I have a 1980 XS1100SG if that makes a difference. I have checked all over the forum and it seems everyone uses rubber blind plugs, I was hoping there was an alternative that won't break and doesn't look like someone jury-rigged it with spare parts. Any help with this would be greatly appreciated.
    Meteor3178
    1980 XS1100SG
    My mods:
    Takt fork brace
    Goldwing handlebars
    Progressive fork springs & shocks
    Blade fuses and fuseholder
    850 Final drive
    Vetter Trunk
    "the meteor lit up the highways"
  • gareth
    • Jul 2007
    • 259
    • New York City
    Are you talking about the rubber plugs that seal off the sync ports on the intake boots?
    After sych-ing the carbs, I connect the nipples on carbs one and four together with some 3/16 fuel line. Same with ports 2 and 3...
    It's like a dumbed down YICS mod...
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      After balancing the carbs, toss in some T-connectors and tube to the vacuum fittings and you will find that your bike will idle smoother...
      Geezer
      • Dan Hodges
        Sensei of Internal Combustion
        • Sep 2004
        • 526
        • A garage in south St.Louis
        You can buy them new from Yamaha.
        • gareth
          • Jul 2007
          • 259
          • New York City
          Less than a minute between Oregon and NYC..
          Gotta love the Intranets, Tony.....
            I buy mine from autozone... Never thought of linking them though! I migh jus try that!
            • petejw
              • 2269
              • sydney australia
              i link the 4 of mine together with t peices,
              figure it cant hurt any.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • dbeardslee
                • 4385
                • Maineville, OH
                Isn't that kind of like making your own YICS? Interesting idea - might have to give it a try.
                On the blind plugs, +1 for the auto parts store. I get a package of 5 at Advance Autoparts for about $2.
                • petejw
                  • 2269
                  • sydney australia
                  hey doug,
                  it is using the same principle as the yics
                  system, i figure it can only be a benefit to help
                  balance the carbs.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    What I find very interesting about this discussion, is that almost all of the XJ owners look for ways to eliminate the YICS. Thus the YICS Eliminator created by one of our own members. And most of them look for a design they can leave in place after tuning.
                    • petejw
                      • 2269
                      • sydney australia
                      i found that interesting too,
                      i dont see any disadvantages of having it connected,
                      and the possibility that it could help keep the carbys
                      balanced cant be a bad thing.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • dbeardslee
                        • 4385
                        • Maineville, OH
                        It would be interesting to see what difference this plumbing makes in the sync at higher rpms. Carbs are synced at idle, but if you watch the gauges, you notice that the sync usually doesn't stay even as the rpms rise. It would be interesting to see what kind of a difference this makes in the sync at elevated rpms - I'm thinkin' it should stay more even. You'd think it would make a sync 'last' longer too. One way to find out....
                          I've tried hooking all 4 carb vacuum nipples together and I found the bike ran worse that way. Took them right off and went back to the blind plugs. YMMV
                          • 79XS11F
                            • 3563
                            • Ottawa, Ont. Canada
                            Carb sync should last a very long time unless your always messing with your carbs. I check my sync every time I tune up and after original set up, I have not had to readjust.
                            Rob
                            KEEP THE RUBBER SIDE DOWN
                            1978 XS1100E Modified
                            1978 XS500E
                            1979 XS1100F Restored
                            1981 Suzuki GS1100
                            1983 Suzuki GS750S Katana
                            1983 Honda CB900 Custom
                            • XS1100 Newbie
                              • Jun 2009
                              • 1106
                              • Battle Ground, Washington
                              If you check with your auto parts store for these vac. caps, you will find that some of them have caps that are about as heavy as the originals. Most of what you find are wimpy thin caps. I think it is Echlin that has heavy ones.
                              1980 XS1100LG Midnight
                              1991 Honda CBR1000F Hurricane
                              A cold beer and another one!
