I am looking to put new brake lines on the front and rear. On the front I just wanted to run 2 from the master cylinder instead of through a splitter. What I noticed is that the factory lines have a slight bend in the banjo bolts but it looks like there is room that a straight banjo may fit. Has anyone used straight banjos with success?
Brake lines
Originally posted by benxs1100 View PostI am looking to put new brake lines on the front and rear. On the front I just wanted to run 2 from the master cylinder instead of through a splitter. What I noticed is that the factory lines have a slight bend in the banjo bolts but it looks like there is room that a straight banjo may fit. Has anyone used straight banjos with success?
my XS11SG has 2 s/s lines from the m/c to the calipers.
Perhaps straight banjos would work at the m/c but I doubt they'd clear the calipers.
If you are getting custom lines made, use a piece of single conductor household wire bent into into place on the bike to determine the length.
Tell the builder the banjos should be clocked at 180º and I reckon, a 7º to 10º bend on each.Fred Hill, S'toon
