oil filter source
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    oil filter source
    Has anyone found a source for oil filters, other than a dealer?
    I got two numbers, one for Fram, one for Purolator.
    Fram CH6002
    Purolator ML16805
    Wix 24933 (Just found this one)
    Ten bucks seems a little steep for a filter, but then I remember when a milk nickle cost, uh, oh, never mind.
    And while I'm asking questions, does anyone know where to buy the little plastic plugs that go in the allen wrench socket holes to keep the dirt out? There are four on the handle bar clamp, and one on the fill plug on the rear gear case.
    Thanks for any leads, CZ
  • cywelchjr
    XS-XJ Super Guru(Deceased)
    • 4450
    • Sacramento, CA
    I don't know about in your area, but I get mine at Kragen's auto parts. Of course you can get them for about 20% more at Cyclegear too.
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      Hi again, you are a font of knowledge.
      Checker is the analouge of Kragen's in this area, (Denver), and I checked with one of the Checkers store, and he said that he doesn't list it in his system.
      Do you have to special order it at Kragens? And what does it cost?
      I can go there tomorrow and get with the manager to see what can be done.
      Thanks again, CZ
        I buy mine at Advance Auto parts, Fram CH6002. They stock them on the shelf.
        • Elevener
          • 608
          • small town in TEXAS
          Copied off the forum at some point
          autozone SP2
          Napa 4933
          STP: SMO-2
          Wix 24933
          Fram CH6002
          **Make sure it has BOTH rubber O-rings in the kit, one for the chamber, the small one for the filter bolt!**
          Trapped in time. Surrounded by evil. Low on gas.
          1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
            • 2074
            If i get desperate-Bike Bandit!
              NAPA has them all day long and usually as many as you want. Not an issue!
              • Geezer
                • May 2003
                • 2985
                • Willamina, Oregon 97229
                Put on one of TC's spin on adapters and you can get oil filters almost anywhere...
                Geezer
                • MindWebs
                  • May 2009
                  • 431
                  • Baldwin, WI
                  there is also:
                  $4.00 each for filters. ($35min. order + $5 S&H)
                  good luck
                  • cywelchjr
                    • 4450
                    • Sacramento, CA
                    Geezer
                    Yep, it's on my list. With my next engine I'll have to paint it black to match the engine though, and then paint the filters too.
                    • Geezer
                      • May 2003
                      • 2985
                      I've already painted my SOFA black and I'm going to pick up a spare filter to paint black. My engine is still aluminum color but I plan to black it out later on... The SOFA and the hydraulic clutch adapter plate are the first 2 black parts going on the engine...
                      Geezer
                        Geezer
                        Anyone know how much he charges for the adapters?
                          Here is a link to the thread on the SOFA. When I look at it ti seems to be intended for an oil cooler application. Perhaps TC or someone can clarify if the cooler is a requirement to use this.
                          • Geezer
                            • May 2003
                            • 2985
                            There are 2 versions, 1 with and and the other without cooler lines. I have the version without cooler lines...
                            Geezer
                            • Welsh1100
                              • Apr 2009
                              • 40
                              • Fairfield, California U.S.A.
                              Oil Filter
                              Fairfield Cycle carries O.E.M. oil filters. $10 bucks a pop. I bought the last 3. Parts are getting more scarce. I did use the Fram filters
                              Some days you're the pigeon..and some days you're the statue/
                              1979 XS1100f
                              Saddle bags, small wind screen and non-original rear shocks. Otherwise..completely stock.
