# 1 & 2 not firing
  • dntemp_ca
    • 167
    • Kenora, Ontario
    # 1 & 2 not firing
    Bike was running great last year, but started up this spring and #1 cyl not firing. Check the p/u wires (previously repaired) all appears good there. Removed and cleaned the carbs (again). Now both #1 and 2 are not firing (cold header pipes). I pulled the spark plug from #1 and grounded it and there is some spark there but doesn't seem to be consistent. I removed the plug cap and cut off a bit of plug wire and reinstalled the cap. Still no joy. Any ideas? Dennis
    Dennis
  • Incubus
    • Aug 2006
    • 1003
    • Austin TX
    No. 1 and 2 carb share a fuel line. I would start there. they do not share spark, so any problem with spark would be a separate problem for each cylinder. Look to the fuel side first.
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
    • dntemp_ca
      • 167
      • Kenora, Ontario
      Fuel is getting thru as the plugs are wet. I installed a fresh set of plugs and it fired up on all four as long as I kept the choke (enrichener) on, but soon began to miss badly again.
      Dennis
        Yep, my bet is a pinched or kinked fuel line, or air bound in line filter something like that.
        • Incubus
          • Aug 2006
          • 1003
          • Austin TX
          If it ran with the enricher on that confirms for me that you have a fuel issue.
          Patrick
          1969 Yamaha DT1B
          • dntemp_ca
            • 167
            • Kenora, Ontario
            Hm, I'm confused Patrick, can you explain? I'll check that fuel line again. I've got the fuel running through on Prime as I was getting ready to sync the carbs and the plugs in #1& 2 are wet with gas. I'm running a Uni foam air filter (clean). Snorkel is clear.
            Dennis
              Well then, if they are wet with fuel, then perhaps you have a flooding issue. Do you have an inline filter to those carbs? Look in the airbox if you have the stock one and see if it has gas laying in it.
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                Did you have gas in the bowls over the winter? If you leave untreated gas in them for a couple months, they'll often get gummed up. Cleaning out the bowls, and the little jets in the bottoms often fixes that. If the bowls were drained, you'll often get a stuck float when you first put gas back to 'em. A rap with the back of a screwdriver on the bowl is usually all it takes to fix that. My $.02
                • dntemp_ca
                  • 167
                  • Kenora, Ontario
                  Well, how red is my face?! I had the fuel supply to #1 & 2 on Reserve and #3 & 4 on Prime. So, yes I did have a fuel issue. Also had the idle screw set waayy too low for the carb bank (after carbs off for cleaning) so of course it wouldn't idle! I figure it was originally been a fouled #1 plug, then I complicated things with the petcock setting when I was getting ready to sync the carbs. Now it's firing on all four, carbs synced....hope to get a test ride in before it rains again! Thanks for the quick feedback, guys!
                  Dennis
                    HOW RED IS IT????!!!!!
                    Just kidding, if we all had a dollar for everytime we thought we had a problem that turned out to be the petcock shutoff, well, some would be richer than others, but we all would be up by at least five bucks.
