i know it's not the bike, i know it's me, but still....all i wanna do is ride the damn thing. so it wouldn't start, and started running rich, so i figured i had a stuck float needle, and would run some sea foam through it and pray. apparently i did a very bad thing. now it is a bit#h to start, and if i let off the throttle it dies, and it has no NO NO power anymore. got it going around the block and no acceleration at all. which sucks, cause that is why i love the bike. it ran well for about two days after the sea foam. any thoughts at all? is this all carb related, or do i have a bigger problem? i'd really appreciate some help, my bike is about the only "me" time i have, and between work, travel and the kids, i don't get much of that to begin with. i just need the thing to start when i want it to start and ride when i NEED to ride....thanks men, i know you'll come up with something.
p.s. i almost had a very tod moment when i finally got it started i was so excited i almost took off in sandals and shorts. but my head got the better of me, and i went back in and changed while it ran/died on me.
. Where in Indiana are you?
. Gravity tends to drag crud down, and that's one place that normally gets sludged up, but a thorough cleaning is best. The last time I cleaned and rebuilt a set of carbs for another member it took 9 hours - start to end of test ride. It's a little tight, but it can be done in a single day if you need help.
