I have a 1980 XS11 Special and just turned 24K miles. I recently noticed a bit of a high pitched whine when accelerating and at high speeds(50 -65). Then a tapping sound which seems to be from the top end has followed that noise. I adjusted the cam chain tensioner(which had not been done for about 6-7K)
That seemed to quiet things a little. I removed valve cover and tolerances are within specs or even closer in some cases. I am at 2k on my oil change using Golden Spectro( partial synthetic). I have checked oil level and drive train levels...all OK. My brother who watches this sight indicated he had seen very little if any valve problems from these bikes. I'm going home now to do a compression check to see if the valves are seating. Any suggestions would be appreciated.
