Miss In Engine
  • Mont
    • Dec 2009
    • 11
    • Central Montana
    Miss In Engine
    My '78 XS1100 has got me perplexed. I've only got a couple hours run time on it since it was resurrected after sitting for about 10 years. At first it ran great (most of the time), then it started not firing on #4. The pipe was only warm. I could pull the plug wire off and put a spare plug in it and it was firing. I thought maybe the valves were sticking. Then the next time I took it out, #4 was firing, but #1 wasn't. Now #1 & 4 are firing, but #2 & 3 aren't. However, I can put a spare plug in #2 wire and the spare plug fires great. Any ideas?
    • 8891
    First thing I would try is unscrewing each spark plug cap and cut 1/4 inch of wire off, then screw the caps back on and try it again. Corrosion forms at the ends and can give you a weak or no spark. HTH
      As eratic as this sounds, I'm with Phil. I think you have one or more corroded connections in your ignition circuit. Also do not overlook that old glass tube fuse box if you still use it.
        I am going with the plug wires too. Does the bike still have the original coils? If so try the new wires in old coils fix then it just eliminates the possible problem of 30 year old wires. You can find that fix here http://www.xs11.com/forum/showthread.php?t=137
        • petejw
          • 2269
          • sydney australia
          I had a similar problem with mine after i replaced
          my engine with a spare that had been sitting for a few
          years, mine was doing it on cylinders 1 or 4, if the engine
          is burning oil be careful not to have the carbs running rich
          it will cause the plugs to foul.
          there was a few times i had to ride it home holding the spark lead just of
          the spark plug to get the cylinder to fire.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • BigRed
            • Mar 2010
            • 265
            • Ottawa, Ontario, Canada
            Have you pulled the plugs? They could be dead or carboned up. I had my bike running way too rich... when I put in fresh plugs, it would run great for about a half hour, then it would idle really crappy. I'd pull the plugs, clean them, and it would run fine for another half hour.
            The reason I was having this trouble was because I had replaced my idle mixture screws, and I put them in way too rich. Each time I pulled the plugs to clean/inspect them, I tightened the mixture screws. I eventually got help from another member with a Colortune, and got them adjusted much better.
            Good luck!
            '80 SG with motor from a '82 XJ
