CArbs connection HELP!!!! Quick!
  • Psychedelic_Max
    No Longer Xsive=sold
    • Nov 2009
    • 40
    • Quebec, Canada
    Okay... I putted back my carbs today and I have a few question now:
    On this picture... I know where is the vacuum but where do I plug it in... A or B.
    And What goes to the other one?
    And on the second picture: where do I plug Gas line and air line?
    Thanks guys!
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    Here, judging from the pictures, A should be connected to your octopus, (the thing that controls the fuel flow), which you have labeled Vacuum.
    B should be connected to the vacuum advance under the left side cover.
    It almost looks like the tube you have on B is the one that should go from A to the octopus.
    A is the "vent" tube, it should go to the air box,
    B is the gas supply, it should hook to the hoses from your gas tank
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • Psychedelic_Max
      • Nov 2009
      • 40
      • Quebec, Canada
      I don't understand what you mean there...:S
        If you look at the left side of the engine the front round cover, under which the timing components live, at the top of it should be a vacuum hose coming out.That vacuum hose comes from the vacuum advance module and needs to connect to the nipple on the no 2 carb which you have labled B.
        • Psychedelic_Max
          • Nov 2009
          • 40
          • Quebec, Canada
          Is this the one circled on this picture?
          • tarzan
            • 1700
            • Chandler,Az.
            That is the vacuum advance hose.Connect it to the #2 carb body.The "B" in your first pic.
            80 SG XS1100
            14 Victory Cross Country
            • Psychedelic_Max
              • Nov 2009
              • 40
              • Quebec, Canada
              Thank you VERY much!
