squirral incident
  • squirral incident
    So for thoughs of you who haven't been keeping up with Hemes's resurrection, I had an incident where my dog cornered a squirral in my work shop right after I'd laid out my carb parts. They got scattered and I have no idea what jets went into which carbs. However after colour tuning and carb tuning today he is working real , real goooood. So anyway I checked the turns for future reference and and here is what I got.#1, 1 3/4, #2, 1.1/4, #3 1.3/4 and #4 0.3/4, Being a betting man I'd say that the parts from #'s 1&3 matched ok but #2 & #4 got mixed. Probably explain the slight stagger at low RPM. He's working good enough not to switch them back this summer but in the winter. I figure I'll play some checkers after I put new rings in.Anybody concur with this?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Honestly, those setting sare all close enough I would be hard pressed to say you have anything in the wrong spot.
      Ive mixed many parts between carbs
      without any problems what so ever,
      have you sync the carbs yet, if not
      do that, then recheck ur mixture screws.
      also if your floats werent set exactly the same between carbs,
      could give you a slight difference with mix screw settings.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        You might want to replace that #4 idle screw. If it is really giving the same mixture with a full turn less, it sounds like it got smashed. So much for lightly seated...
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
          [color="darkred"]replaceable,[/color] parts
          ANY replacement parts on carbs are REPLACEABLE, ergo matching and keeping separate is of no concern on rebuilding.
          However you must tune and sync for the carbs to run right and that operation eliminates any discrepancy between parts and makes all things equal.
          Factory tolerances allow tuning and syncs to make up for mismatched parts. This is true an any replaceable part.
          My $$ worth on this argument.
          Dell82
          Dell82
          Houston, TX
          82' XJ1100J Maxim "LASERMAX"
          SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
          SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
          SOLD 82' CB450SC Nighthawk, parts bike SOLD
