Rear brake issues, it works but not really....
  • Incubus
    • 1003
    • Austin TX
    The back brake on my '79 Standard works, but not particularly well. When I step on the pedal I get back pressure and the bike then slows somewhat, but it does not grab and could never lock up the wheel. I do not know if it would bring the bike to a complete stop.
    The rear master and caliper have been cleaned and rebuilt. They seem to be functioning properly. The rear brake pads are relatively new. The system is properly bled. It has a new steel braid brake line (which is a touch too long, but no radical bends or kinks). It seems to be an issue with the brake pad that is NOT pushed by the piston. Like maybe something is missing that makes it too movable so the disk never gets properly pinched.
    My front brakes are working very well and I really don't use the rear brake that often, but I would like it to work right so I know it is there in the event of front brake failure. Has anyone faced this issue? What should I be looking for?
    Patrick
    XS11F (Incubus, daily rider)
    1969 Yamaha DT1B
  • psycoreefer
    • Feb 2008
    • 1557
    • Minden, NV
    If you remove the capliper and push the piston in and then put it back on the bike you should be able to move the entire caliper back and forth a short distance, if you can't you need to take apart the sliding bolt part and clean it up or replace it.
    I suspect that the issue is that the bolt is rusted and now allowing the caliper to slide and center over the rotor...
    The parts in question are parts 6,7,and 8 on this fishe....http://parts.yamaha-motor.com/partim...7522,5,0,sport
    1979 xs1100 Special -
    My Bike:
    [link is broken]
      Well at least your work some! I just cant get mine to bleed no matter what I do! Good luck!
      • Incubus
        • 1003
        • Austin TX
        I used a power bleeder to bleed mine, Nate. It is a wondrous invention. I took the front brakes from empty system to bled and working inside of 20 minutes. The back was even quicker.
        1969 Yamaha DT1B
        • dbeardslee
          • 4385
          • Maineville, OH
          When I bleed XS brakes I start with a power bleeder to get fluid into the entire system. Once I've got fluid, I do it the old fashioned way. Pump the brakes up, hold them, and crack the bleeder valve quickly. You only need about 1/4 turn, but you need to do it fast enough that you don't allow air back into the system. A little piece of clear tubing on the bleeder valve helps too. It allows you to see if any air is coming out of the bleeder valve, and also keeps you from squirting brake fluid all over the place. If you didn't use tubing when you were bleeding, you might have contaminated the pads which can also give you coaster brakes. My $.02.
          • Incubus
            • 1003
            • Austin TX
            Wow, that was too easy. The bolt was rusty. Now it is shiny and I have rear brakes. I still don't know that they will lock up the wheel, but they will stop the bike. I don't want the wheel locking up anyway...
            Thanks, Psyco.
            Patrick
            1969 Yamaha DT1B
            • psycoreefer
              • Feb 2008
              • 1557
              • Minden, NV
              You should be able to lock the rear wheel if everything is working as it should. BTW, if you have some brake caliper grease to put on that sliding bolt and its rubber boot it will help to prevent it from freezing up again, you only need a light coating.
              My Bike:
              [link is broken]
