broken idle mixture screw syndrome
  • Brad
    • 136
    • Regina, SK CANADA
    With the broken idle mixture screw syndrome, can you sharpen and reuse the broken tipped ones or do you need new idle screws?
    Some make 'em, most just make payments on 'em!
    1978 XS 1100E
    Vance & Hines Slip on Straight Shot Exhaust
    K & N Air filter
    Home built forward controls
    Vulcan Mustang seat
    A little chopped
    http://s812.photobucket.com/albums/zz42/Brad_099/
    • 8893
    Yes, it'll work in a pinch, I've done it, doesn't work as well as new ones.
      Wouldnt you still be running extremly rich because the tip is still gone and it is shorter?
        Nathan, he is planning to reshape the tip back to stock, well, close to it. Any way you go about it, you the thread on those screws is pretty fine and you should be ablt to adjust it down where it can get close and run decent. .
        I have never owned an earlier model XS11 so never dealt with it, if Phil says it ain't the same, then it ain't the same.
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          i am currently running on 2 broken screws. i have had the bike for3 years and they were broke by the po... new ones on the way. my bike runs ok with them broke
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
            • 5073
            I would guess that you (or prevous owner) got the tips out of the jet holes... Yes, you can get the adjustment to compensate. It is more "touchy" however.
            • Brad
              • 136
              • Regina, SK CANADA
              I think the tips are still in there, it will not idle, slows down then stalls out. If I adjust my idle screw or throttle screw, rev too high and take about 30 seconds to slow down.
              1978 XS 1100E
              K & N Air filter
              Vulcan Mustang seat
              A little chopped
                Hi Brad,
                if the busted off tip is not still plugging up the hole in the carb., a resharpened screw will kinda work but a new one will work better.
                If the tip is still in there, it gotta go.
                My son's XS750 (same carbs) had a needle tip jammed in it's #2 carb. We tried all the removal tricks the search button could show us to no avail.
                The hole should be 1mm diameter.
                The smallest drill-bit my bench drill chuck will grip is 1/16" so that's what we drilled it out with.
                The fix works just great with a new needle although it needs to be screwed out ~1/2 a turn less than the other two.
                • jmnjrpa
                  • Jun 2009
                  • 863
                  • Lewisville, Texas
                  Hmmmm
                  May not work too well if he has the later model carbs, the ones with the slender "tit" on the end past the taper.
                  Original except:
                  Big John
                  • Brad
                    • 136
                    • Regina, SK CANADA
                    Are these tits?
                    Great advice. These are the screws, as jmnjrpn said these might have tits.....
                    Can someone tell me if these are tits?
                    1978 XS 1100E
                    K & N Air filter
                    Vulcan Mustang seat
                    A little chopped
                      Those are decisively the older style mixture screws. They look like the tips have been broken off of them.
                      The newer ones jmnjrpa referred to come to a well defined shoulder then begin with a notably smaller diameter down to a dull point. The smaller taper is more than twice as long as the tip on your fourth screw there. It is also a much different configuration.
                      • jmnjrpa
                        • Jun 2009
                        • 863
                        • Lewisville, Texas
                        No
                        Those are screwed screws. Like Don said, they are very different. Yours are in BAD shape.
                        Original except:
                        Big John
                        • Ken Talbot
                          • 4251
                          • Revelstoke, BC
                          Here's what the newer style ones look like:
                          Ken Talbot
                          • Brad
                            • 136
                            • Regina, SK CANADA
                            Thanks All, looks like I have some work to do and this is why she wont idle... Still runs like a champ and gets over 175Kmph
                            1978 XS 1100E
                            K & N Air filter
                            Vulcan Mustang seat
                            A little chopped
                            • GARTHXS
                              • Nov 2007
                              • 1631
                              • Seattle
                              btdt!!!!!
                              Do a search for the freezing method it works well
                              91 kwaka kz1000p
                              Stock
                              ( Insert clever quote here )
