Please HELP,How is the slide & needle assembled
  • indy400
    • Feb 2010
    • 5
    • Wahpeton North Dakota
    Hello, I have a question for anyone out there. How does is needle, E-clip, washer, plastic spacer , spring go in the slide on a 1978 xs1100E
  • dbeardslee
    • 4385
    • Maineville, OH
    Indy - Welcome to Ch11! Many assembly questions can be answered by the Yamaha parts fiche. Go to the parts catalog, key in the particulars, click on carbs, and blow the diagram up as big as it will go. Find the parts, and check below the diagram for the description. I'd do it for you, but thought it would be better to teach you how to fish .
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      On my 78 and 78 standard models the needle spring goes in the hole at the bottom of the slide (on the inside) the clip goes in the middle position on the needle, the small washer is under the clip so it is between the needle spring and the clip, and the plastic spacer goes on top of the clip. The whole assemble goes through the spring in the bottom of the slide. Once in place you pull and hold the needle in the full down position and install the plastic needle holder followed by the large clip that secures everything in place. The plastic needle holder only goes in one way due to its offset pins. Make sure the large clip is fully seated inside the slide.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • indy400
        • Feb 2010
        • 5
        slide needle assembly
        thanks the info was very helpful.
