carb idle circuit
  • the108penguins
    • Apr 2010
    • 130
    • Gainesville, Florida
    carb idle circuit
    carb number one still wont let in any fuel during idle. I've triple cleaned all of them, synced and colortuned too. went to color tune and saw that #1 wasn't burning at all. not sure why? Ideas anyone?
    79 XS1100 Special
    Kerker 4-1, Pods, BS34 old style carbs, plastic floats, 147.5 mains, progressive rear suspension (restoring)
    • 8962
    Check to see if the tip of the idle mixture screw is broken off and stuck in the carb body.
    • dbeardslee
      • Nov 2007
      • 4385
      • Maineville, OH
      Still got the stock coils? If you're not seeing anything on the colortune, it's most likely the carbs or the ignition. Many times ignition coil problems will do a pretty good imitation of a carb problem. Might want to test your primary and secondary resistances on the coils. Might want to check your pickup coil wires too. JAT
      • Incubus
        • Aug 2006
        • 1003
        • Austin TX
        JAT, there are three small little holes into the throat of the carb right about where the butterfly hits when it closes. When you spray carb cleaner into the hole the slow jet screws into, the carb cleaner should bubble up through those three holes. If it does not, then your pilot circuit is not clear.
        My carbs bedeviled me for weeks until I saw a post by Topcat that talked about those damn little holes. Once I got them clean, all was well.
        That may or may not be your problem, but it is one more place to look.
        Patrick
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
        • the108penguins
          • Apr 2010
          • 130
          I know the electrical is alright cause the coils have been replaced and whn I had the colortune in I could see a nice bright fat spark but other than that it was dark in there. I'll check the tiny holes you mentioned. gives me a place to work from.
          79 XS1100 Special
          • yamtom
            • 275
            • Midland Michigan
            carb bowl tiny jet
            Hi ,
            I was bedevilled by the same issue, but it amounted to the bowl jet being blocked, carb spray must go thru that to get into the pilot system.
            Bikes Now.
            80 MNS 11 pods,georgefix kit,stock jets, HD Sporty muffs
            79 XS 11 Special, Emgo pods, stock jets, with Pacifico fairing, hard bags, intact stock pipes Sold
            83 Yammi Venture with custom footboards, 20k miles.
            83 Yammi Venture parts bike
            99 Valkyrie shield and bags 37k miles like new
            08 ZX 14 Kawa Ninja 6k miles Sold
            • SFerinTEXAS
              • Jun 2006
              • 877
              contrare bowl jet is only for the enricher someone correct me if I'm wrong
              79SF
              XJ11
              78E
