Ok, I'm doing the swap and have a couple questions. I read the swap thread but stii confused...
1 is the only reason for undoing the pinion retaining nut is to put sealant in the two holes? I dont need to pull anything out right?
2 The whole 750 drive is used as is with nothing swapped from the 11 except the shaft and spring right??
