Problem is, I kept snapping the small ones in two. Yesterday I was cleaning a handlebar switch, and one of the little million-year-old screws decided it didn't want to come out. It was in a very tight location, and I couldn't get any kind of pliers on it. With the tiny little head I was a bit worried about drilling it out and using a conventional EZ out. I zipped up to my local Home Depot, and picked up a set of Alden Pro Grabits. You put them in a drill, set it on reverse and burnish the head with one end. Then you flip it around and use the other end to extract. These tools REALLY work good, and they're much beefier than EZ outs. Just thought I would pass it along.
I'll never buy EZ outs again
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesTags: None -
I agree!! I have the set of 2, and they have helped a few times on my bike. I did, however, break one off trying to remove a stuck bleeder valve.So, now I have a set of 1.5... They ARE better than the standard style of ez-outs though.
-H. Ford -
Those are cool ...
but I learned my lesson long ago regarding easy outs ... it's a misleading term. Often, not only are they NOT easy ... they are hard.
They are designed for brass and tapered pipe thread fittings. Using them on a stuck or broken-off bolt often leads to the next step ... acetylene torch and O2 blast.80G Mini-bagger
Past XS11s
79SF Squared-off Special, Vetter/Bates tour pkg., Mikes XS coils, G rear fender and tail light. Sold June 09Comment
Ez outs work great as stated on soft metal fitting. They usually suck really bad at everything else. I will have to try some of these and see how they work!Nathan
Theodore RooseveltComment
I have a set of those I bought at sears.They are excellent.
I have used conventional ez outs as well, which are a PITA!
As far as I am concerned though, bolts that are actually seized rather than
just broke off or stripped need to be drilled out and tapped.80 SG XS1100
14 Victory Cross CountryComment
Never seen them here, and they look way better to use than EZ outs for smaller screws and bolts. http://thegrabitstore.com/default.aspx The website says they cant ship international so who wants to buy me a set and ship 'em over.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
As far as I am concerned though, bolts that are actually seized rather than just broke off or stripped need to be drilled out and tapped.. It grabbed pretty good when I put it back in, and with a little luck it'll be another 30 years before it sees daylight again. If I couldn't have gotten that screw out, it would have meant a new switch - I figure these things paid for themselves on that repair alone.
so who wants to buy me a set and ship 'em over.. If they don't sell them in NZ, you should check into a distributorship. You could probably get a free set that way
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
EZ outin
I have a set of Left Hand (CCW) drill bits that come in handy.
They bite like that special tool does, and usually spins them right (or left) out.1980 Yamaha XS1100G Lowered, 4-2 , Pods , Jets
1973 Triumph TR5T Trophy Trail - almost original
1973 Plymouth Duster - nothing originalComment
