Psycoreefer,
Have you tried ordering a seal from Yamaha?
That's the route I recently took for mine. Had the same problems... both sides.
The Yamaha's are 2 different seals & part #'s for each side. LH side (advance) has a case lip... RH side, (Alt.) doesn't.
I ground the outer lip down & placed a film of Yamabond around it... tapped it in on the LH one.
Had the same oil leak thing going on w/ mine on the RH side... replaced the O-ring on the galley plug... helped, but didn't solve it. Ordered and installed the Yamaha seal... problem solved.
If you do a search on 'Galley Plug', you'll find a thread where Trbig was goin' through this a few years back, and found a tap and a plug to replace the galley plug with. That way he could run his w/ the cover removed... and he permanantly fixed the O ring oil leak he kept having. There's pics & details in that thread how he did it.
Perhaps it's just because of the aftermarket seal?
Understand why you're going that route... Yamaha's $12 per seal sucks! But... how much trouble has the $3 one cost? $9 worth yet?
Could be way off here, and it's something else wrong... but I'd order one from Yamaha and try it one more time.
If it doesn't do the trick, you may have to go the speedy sleeve route.
JAT. Hope ya get it figured out soon.
Bob
Bob
