Which ignition coils to use??
  • mlew
    • Jun 2005
    • 226
    • Apex , NC
    I'm replacing the coils on my 80SG. I have several choices. Dyna and Acell make coils that fit these specs
    1- 1.5 ohm coils and leave the ballast resistor.
    2- 3.0 ohm coils and remove the ballast resistor
    Which route should I go? Is there any advantages or disadvantages to either setup?
    Dyna makes a mini coil DC1-2 it looks like it would be easier to mount. Anybody ever install a set of these?
    Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
    Current rides:
    80 XS1100SG
    82 JX1100
    83 Venture Royale
    86 V-Max
    The common choice is the green coils from MikesXS.com. They sell a better, black version too, but they are usually out of stock.
    • Crazcnuk
      • 2980
      • Hinton, AB, Canada
      http://www.mikesxs.net/products-27.html#products
      Part #17-6803 are all you need. They put out far more than the stock coils ever did and bolt in the stock location with no mods.
      The green coils would be good if your going to run a turbo, supercharger or nitrous, but are overkill for an otherwise stock motor.
      Either way don't forget spark plug wires.
      '05 ST1300
        The 3 ohm and lose the resistor is the way to go. One less part to fail.
        • mlew
          • Jun 2005
          • 226
          • Apex , NC
          I forgot about MikesXS, I'll ckeck them out.
          Current rides:
          80 XS1100SG
          82 JX1100
          83 Venture Royale
          86 V-Max
          • mlew
            • Jun 2005
            • 226
            • Apex , NC
            What is the primary resistance of this coil? It does not say on the website. Do I need to keep the resistor plug caps or can I loose them?
            Current rides:
            80 XS1100SG
            82 JX1100
            83 Venture Royale
            86 V-Max
            • mxmikie
              • Aug 2008
              • 482
              • Bouse az
              i used the honda vt1000 coils 3 ohm
                Hte MikeXS black coils have been known to go bad in a relatively short time span. Several members have only gotten a few seasons out of them. That is why many step up to the green coils.
                I have not changed my stock coils out, but I believe you still use the resistor plug caps unless you run the resistor plugs.
                  The TCI does not care what the resistance is on the spark plug wire side, just the power input side. The resistance caps are for radio supression only. You can run any type caps you like. If you're using an electronic device while riding, use either resistance caps or resistance spark plugs.
                  • CA
                    • Feb 2009
                    • 267
                    • Nashville, TN
                    Green Coils
                    I have the Green Coils coming in the mail. Can't wait. It is a horrible feeling experiencing your coils demise.
                    I forgot plug caps, so i will get some at a local auto parts store. I may need a little help on the install when they get here...but thanks to beardslee it seems like a simple install.
                    1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
                    • dbeardslee
                      • 4385
                      • Maineville, OH
                      I had a set of the black ones (17-6803). They lasted 7k miles and crapped out. I'd opt for the green ones, or a set of Dynas from Z1 Enterprises. The Dynas are basically the same spec as the black mikes coils - 3 ohm primary resistance, 30kv output, but with beefier windings. The green mikes coils put out 45kv with a 12v input, and 75kv with 14v input. Whatever coils you decide to go with, don't forget to open your plug gap a bit - .035"-.040" on the green monsters, .035" on the black mikes and dynas. NGK Iridium plugs pair very nicely with either.
                      • Winterhawk
                        • Jun 2004
                        • 684
                        • Missouri
                        How about Accell, Which ones and keep or eliminate the resistor? I forgot and I also was interested in coils sometime soon.
                        • BigRed
                          • Mar 2010
                          • 265
                          • Ottawa, Ontario, Canada
                          I've got a set of the black Mike's XS coils, but I haven't installed them yet. Hopefully They last more than 7k miles! I guess I won't be doing any long trips without my old ones as spares.
                          I've already eliminated the ballast resistor on mine... just one more thing that can fail, and I don't like the idea of wasting energy through a resistor when it could be going to a spark.
                          • MrOzz
                            • Aug 2008
                            • 782
                            • Massachusetts
                            Originally posted by DGXSER
                            The MikeXS black coils have been known to go bad in a relatively short time span. Several members have only gotten a few seasons out of them. That is why many step up to the green coils.
                            I will not buy the black ones from Mikes XS again. Had them for a short time before they died. Only had them about 3 months
                            1980 XS 1100SG
                            Dyna 3 Ohm Hi Output Coils
                            Pod Filters
                            DynoJet Kit
                            T.C.'s Fuse Block
                            V-Max Auto CCT
                              Yep, the black MikesXs ones quit on me too, 10 miles from home, had to limp it back on 2 cyl.
                              +1 on the 3 ohm Accels.
