I don't see how that could be true, if your using both brakes properly any more "negative acceleration" will cause the tires to skid and thats bad. Stock XS brakes have more then enough umph to skid either tire, at least on both my bikes, and especially the back tire which is the only one the engine is hooked to. I'd say the only way engine braking could help in an emergency stop is if your not using the back brake to begin with.
That said, I do use engine braking while riding around, however "panic" mode is clutch in, down shifting and both brakes applied until I hear the little "squeek" that says anymore and I'll be sliding. That is the proper emergency technique, because:
1. You need to be in the proper gear for road speed so if you have to you can "add" power and get out of a bad spot. Example you may need to shoot out on the shoulder to prevent becoming a pancake if the guy behind isn't paying attention to the idiot that just pulled out into your lane.
2. You don't want to stall the motor, same reason as #1
3. You want to stop as quickly as possible - the brakes are perfectly capable of this without the engines help
4. Its less "things" going on to down shift with the clutch in, then trying to engine brake between each shift and not "over brake" the rear wheel.
Panic stops should be practiced on a regular basis - if you don't your cheating yourself of the few feet that could be the difference between life and death!
