First gear issue?
  • Sgriger534
    • 66
    • Farragut, IA
    First gear issue?
    My bike seems to grab a little when you first put it into first gear, is that the first-seconds gear issue i keep seeing posted? It kicks a little hard going into fist, but dosen't do anything going into second
    1978 XS1100
    These bikes DO sort of "chunk" into first. The "first/second" gear problem is when you get on the throttle HARD and the gear sounds like a machine gune, and seems to slip. To keep it from making so much noise as you shift into first, pull in the clutch about 5 seconds BEFORE you try to shift into first.
    • Montreux_Blue
      XS-XJ Guru (Deceased)
      • 1143
      Try adjusting the clutch a little.
      Famous Myspace quote:
      • petejw
        • 2269
        • sydney australia
        jat, if the idle is set a little high,
        the bike will clunk into gear.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
