Hey Incubus, Is your pic of a Standard with a 16" special wheel?
I tried to set mine up like you have it. I simply do not have enough room for that spacer in between the Brake and Torque brackets. I am using the Standard brake CALIPER bracket. As a matter of fact, I can not see a difference, between my Std and my Special CALIPER bracket, They are identical, even have the same number cast in them. THe TORQUE brackets (far right) ARE different, and I am using the Special torque bracket. Std TORQUE bracket simply doesn't work unless you have the spacer in between the 2 brackets, which I don't have room for that spacer.
In the end, if all of the Swingarms, axles and Rotors are the same, then it shouldn't matter if we're talking about Standard bikes or Special bikes. There should be ONE correct setup for a 16" wheel, and ONE for a 17" wheel. Right?
