I looked at some of the posts on oil levels, but want to run this by.
A week or so after the second oil change, where I did not change the filter due to a stripped oil bolt, I noticed my oil level wasn't showing thru the window. I had put on about 700 miles since the last change, the bike was on the centerstand after riding for a few hours, and sitting for an hour. There are no leaks visable, and it burns no oil that I can tell.
I fired the bike up and let it run for 10 minutes, shut it down, and checked 10 minutes later-same deal. So I added about 10 ozs. of oil, the level showed about 1/2 way between min and max and I figured I'd keep an eye on it.
Next morning-no oil again! I did the run 10 minutes/sit 10 minutes deal again-NG. So I took it for a ride, and the level came back up after I parked and let it sit for a while.
Now the level is down again, after another 500 miles. WTF? I've combed this bke for leaks, it blows no smoke, doesn't smell like it burns oil.
I read the comments about no leak/no burn oil useage, but have never had any vehicle do this.
On the brake issue, I have serious squeals from the front. I read a lot of the threads, and took off the calipers to inspect them. The screw that is supposed to hold in the pads is missing-on both calipers.
When I went to buy some others, I was told you have to buy a new set of pads; that's the only way you can get the screws. $60.00 for 2 screws? Somebody HAS to have found a way around this one-I hope.
Comments, ideas?
Comments, ideas?
(Stupid $10 min purchase with the card when all I needed was the filter) No...seriously though, 20-50 seemed to help with the oil usage. Seems like I have to watch my level more closely when Im using 10-40 over the 20-50...
