Ok, here's what's probably a strange one. My drain for the gas cap area is almost completely plugged. It will drain eventually, but it takes a good while. Any hints on a good easy way to clear that line out so that it drains properly? I've tried blowing air through it from the bottom end and it didn't really do anything. I've thought about trying from the top, but don't really expect that to work either. Maybe I can push a wire coat hanger up through it? (assuming I can still find a metal hanger anymore
). It's been a little disturbing recently seeing the water sloshing around in there after the rain, and of course after washing it (of course the washing part only happens a couple times a year
). Worse, I'm worried about some of it slipping past the cap seal and getting inside the tank, which I'm sure wouldn't be good for proper running etc.
