It's frozen
  • XJ Rob
    • Apr 2009
    • 161
    • Kimball, Michigan
    It's frozen
    I was working on my dads 81 Special and the bolt that holds the oil filter housing on, is frozen. Seems to have been that way for a long time. The PO rounded the bolt off with I'm assuming "Vise grip". I've tried pounding a socket onto the bolt and WOW! it just won't come loose. The socket just slips off or rounds it a little more. Anyone ever have this problem? How did you finally get it out.
    He did change the oil but we really need to change this filter.
    Thanks
    Rob
    82 XJ1100
    Stock..With a few cosmetic changes.
    Current Project..Dad's 81 1100 Special
    http://s727.photobucket.com/albums/ww272/RiderXJ/
    • 8643
    Hammer and cold chisel. Bite into the washer part of the bolt and spin it around CCW. New bolts are available for less than $10. HTH
    โ˜ฎ
      Wel, I think you said it yourself, Vice Grips. Your not going to hurt that bolt any further and it could get it loose.
      If you have toruble tracking a new bolt down, I have an engine I am parting out.
      • Rickrod3
        • Jun 2009
        • 721
        • Oakland, New Jersey
        Pipe Wrench
        got mine off with an 8" pipe wrench used a 3/4" pipe for leverage.
        After you get the bolt off Someone suggested to weld a nut to the bolt I think it was Ken Talbot.
        I thought it was worth mentioning.
        650SF
        XS1100SG Project bike
        • Geezer
          • May 2003
          • 2985
          • Willamina, Oregon 97229
          I've found they spin out real easy with an air hammer like the cold chisel method described above.
          Tony
          • brcree
            • Mar 2010
            • 388
            • S.C.
            bad bolt
            When you put a new one back in, coat the threads with pepto bismol....yes the pink stuff. Great anti seize stuff. We used it in the Air Force on F-16 Jet engine parts! I put it on my spark plugs as well......any hot section will need this to remove bolt later.
            At this time:
            1985 Goldwing Innr.
            1976 cb 750 cafe racer
            2007 vtx 1300
            81 sx 1100 s h
            81 sx 400 special
            • HobbyMan
              MeatHead Idiot "GURU"
              • Jul 2006
              • 1801
              • Colleyville, TX
              Remember, when you replace it, USE A SIX POINT SOCKET!
              Acta Non Verba
              • dbeardslee
                • Nov 2007
                • 4385
                • Maineville, OH
                Bolt outs work well, and will help avoid any collateral damage. They're basically like EZ Outs, only they're for bolt heads. I had a lug nut frozen on my Jeep, and my impact wrench rounded it off. I took a bolt out, pounded it onto the lug nut with a 3 pound sledge, and put a 4' breaker bar on it. Sounded like a gunshot when that sucker let go . Great tools.
                • XJ Rob
                  • Apr 2009
                  • 161
                  • Kimball, Michigan
                  I'm going to try the air chisel. It was my first thought although the "Bolt Out" looks like a tool to have around anyway.
                  Not sure when I'll be able to get to it. I'm hoping Thursday.(calling for rain) So much yard work to do and I only have a couple more days off before I get back to work.
                  I'll give results when it's out.
                  Rob
                  82 XJ1100
                  • Bulldog9
                    • 31
                    • Alexandria, VA
                    Very common problem, over the years, I've welded a new nut onto the rounded off one, cut a slot with a dremel tool and then , and also used the dremel tool to cut the rim off the bolt. Best was the quick spot weld.
                    I found putting a dab of grease where the bolt snugs to the housing has been the best preventative. I rarely ride my XS's anymore, and shameful to admit, just changed the oil in my 79XS11 last week (first time in 5 years...) bolt came right out. Corrosion on the filter housing and bolt contact is the issue with such a small hex head, BAD combination.
                    New bolts are available, same used for XS11 & 750-850. Old Bike Barn is where I got mine.
                    Biggest issue is DONT overtighten ;-)
                    2005 FJR 1300 "Mission" (NON ABS)
                    1979 XS 1100 SF "Visitation" Owned since 1984 - SS Brake Lines, TKAT fork brace, Progressive Fork Springs.
                    1978 XS 750 D "Motivation" - 9" rear custom shocks, dropped front end, shaved seat
                    When Caged:2006 Jeep Commander, 1986 Cutlass 442, 1976 Porsche 912E (latest project)
                    • XJ Rob
                      • Apr 2009
                      • 161
                      • Kimball, Michigan
                      It's Out
                      I was able to get the bolt loose using and air chisel. Only took a couple hits and I was able to spin it out the rest of the way with vise grip. Now we just need to get the carbs straightened out and test drive to check for trans problems if there are any. Only 16K on the bike so I'm hoping NOT!!
                      Ride Safe
                      Rob
                      82 XJ1100
                        Good deal Rob! Glad it worked out.
                        As to the tranny issue, it is always hard to tell. Mine only had 23k miles and had the issue, a local fellow xsive has over 80k miles and never had a problem one out of the tranny. I thinkit is more an issue of how hard those miles were than how many.
