what happened to my mid range power?
  • freak_leg
    • Aug 2009
    • 152
    • Lakeville, Minnesota
    Ok guys, to i messed with the beast a little bit today. Found out i cant move the needle under the top cover of the carbs, however I found one of my fuel lines had a small kink in it, flowing but not alot. I moved the lines around and went for a ride. Just a short one around the neighborhood. enough to wind out first gear and it didnt seem to lug down. Could a slightly restricted line cause this? or is this just a fluke?
    Tony
    78 xs11 aftermarket 4-2 HD mufflers, whats left of it is stock. A work in progress for sure.
    • Incubus
      • 1003
      • Austin TX
      I don't think a kinked fuel line would affect only midrange power. That would most likely cause an issue with top end power when the bike is using the greatest amount of gas. The carbs live off the fuel in the bowls, not the fuel flow from the lines, so whatever empties the bowls the fastest would be the most affected range.
      I still think you have a needle issue. Did the needles appear to be shimmed? That would most likely have been the cure for straight pipe midrange fuel starvation.
      JMHO.
      Patrick
      XS11F (Incubus, daily rider)
      1969 Yamaha DT1B
      • petejw
        • 2269
        • sydney australia
        Did you find out what size main jet
        your running?
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • freak_leg
          • Aug 2009
          • 152
          I did not find out what size my main jet is. Would you mind letting me know how i would go about figuring this out? sorry like i said. limited carb experience.
          Tony
          • Rickrod3
            • Jun 2009
            • 721
            • Oakland, New Jersey
            The only way I know is to remove the jet and read the number off of it.
            I'm a student of Carbs as well as I understand it
            Upper range about 6k to red line mostly affected by Main jet.
            4K to 6K needle height.
            3k to 4K float height
            below that pilot jet.
            HTH
            Rick
            650SF
            XS1100SG Project bike
            • petejw
              • 2269
              • sydney australia
              remove the float bowl,
              the main jet sits on the top
              of the tower, and screws into the bottom of the emulsion tube,
              it should have a number stamped on the top or the side,
              that number is the size of the main jet.
              let us know what size they are and we can go from there.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • petejw
                • 2269
                • sydney australia
                heres a link to Wildkats
                excellent write up 'Carbs 101"
                the first pic shows a carby with the bowl off
                with the main jet exsposed.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • psycoreefer
                  • Feb 2008
                  • 1557
                  • Minden, NV
                  I've got the same stumble, always hits around 4.5 - 5.5, same cold or warm, same with the choke on or off. I've got stock jets, stock float level, stock air box, mac 4-2 pipes and needles raised one clip. I'm really interested to see what solves your problem. FYI if I drop my needles to the stock position I have really bad stumble below 3.5K.
                  1979 xs1100 Special -
                  My Bike:
                  [link is broken]
                  • petejw
                    • 2269
                    • sydney australia
                    hey psyco,
                    looking at your signature and the sounds of your
                    problems your probably running rich,
                    the stock jets are 137.5,
                    by raising the needle your also running it on the rich side,
                    if a stock air filter is fitted and your running the mac exhaust
                    you wouldnt need to change it from stock.
                    are the emulsion tubes the exact same ones as the ones you
                    replaced or are they an aftermarket part?
                    what size pilot jets are you running?
                    just a couple of things to think about.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • WMarshy
                      • Apr 2009
                      • 2402
                      • Mexico NY
                      Your bike/carbs should have adjustable needles... The '78 and '79 carbs have adjustable needles so this might be contributing to your probelms. Maybe someone put on the later style carbs. If they did, we will be able to tell from the jet sizes... Take a look and report back to us.
                      '79 XS11 F
                      Stock except K&N
                      '79 XS11 SF
                      Stock, no title.
                      '84 Chevy K-10 "Big Blue"
                      • psycoreefer
                        • Feb 2008
                        • 1557
                        • Minden, NV
                        [hyjack]
                        Originally posted by petejw
                        hey psyco,
                        pete, I don't know what you mean, my signature says I have 137.5 mains and 42.5 pilots, stock sizes..,
                        Ok, so I updated my signature after your post to make you look crazy.
                        Anyways I am running stock size jets right now. My signature was just a little out of date. And yes the emulsion tubes were NOS from yamaha, but I did replace the center ones with the "richer" ones for the outer cylinders so its running the same all across.
                        I know that I shouldn't "need" to tweak anything for my setup and yet I've been through everything I can think of and I have but three options:
                        1. Run the needles one clip up and deal with a stumble at 5k-ish
                        2. Run the needles stock and +4 size idle jets, and carry extra spark plugs in case I sit to long at a traffic light because if fouls plugs at idle (BTW this is what the PO was doing)
                        3. Run completely stock setup carbs and have an off idle through 3.5k stumble that is so bad that the bike is unridable.
                        I choose number 1, because it is the least "hassle". If your really interested I had a thread a while back about the issue with all my findings and what everyone suggested, you could read through it and see whats been tried, I really would like to solve the issue but I'm just plain flat out of ideas. Really my working hypothesis is that the PO either cut the slide springs or drilled out the holes in the slides, or both, causing it to lift early and/or fast and requiring the strange setup, but every time I ask, no one seems to know what the length of a stock slide spring is, or what diameter the holes in the slides should be, and I don't have the money or desire to buy another set of "early" style carbs just to find out.
                        [/hyjack]
                        My Bike:
                        [link is broken]
                          Psyco, I just checked this for you on my 79 Special. Spring length is 91MM, slide hole diameter is a #42 drill bit (.0935"). HTH
