I have a 81 xs and i was wondering if i could use the kickstart if i just put a kick lever on it. I see the shaft and it seems to move the engine when i move it.
81 kickstart
Tags: None
The 80s bikes lack not just the kicker but the internal gears as well. You have to split the cases and install the gears.'81 XS1100 SH
Sep. 12th 2015
RIP -
i just found it it is a 78, would it be possible for it to have electric start and no kickstart on it, it has the kickstart shaft, and if you turn i by hand it seems to catch1978 XS1100Comment
The guys that are kicking these on a regular basis are using 750/850 Yamaha triple levers I think, although if you do a forum search you may turn up some other choices too.
I never saw the attraction personally, but to each his own...
'78E original ownerFast, Cheap, Reliable... Pick any two
