XJ exhaust on F
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    XJ exhaust on F
    Well, just learned the hard way, XJ exhaust system will not fit on a 79 Std. I got it hung in place, and the crossover will not clear the center stand, the mounting brackets are in the wrong place, nor will it clear my floorboards. The mounting could be solved quite easily, but I WILL NOT give up the center stand or the floorboards. I had a Jardine 4 into 2 (not spaghetti), and it leaks in several places. I guess my only alternative is to get some pieces of pipe and start welding. I do have the header pipes from a Midnight Special, maybe I can mate them with the Jardine mufflers. I am too frustrated to try it all right now. So, I have a pretty good set for an XJ. But, I wonder if the shipping is more than the system is worth. Anyone want to trade?
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    76 CB 750 (gone to MC heaven)
    rover has spoken
    • 6762
    This XJ exhaust is it the stock setup 2 into one on each side? Or is it aftermarket?
    • rover
      • Jan 2004
      • 765
      • central WI (715)
      Xj
      It is original, 2 on each side, with the slash cut megs, but not perfect. Some rust pimples, and one small hole at the bottom of one muff
      79 F (Blueballs)
      79 SF (Redbutt)
      81 LH (organ donor)
      rover has spoken
      • billsxj11
        • Apr 2010
        • 11
        • Indiana
        What does the front pipes look like. My mufflers are nice but I need some clean from pipes for my XJ.
        82 XJ1100
        77 KZ1000
        84 VT700
