Hey. wanted to post this as I leave for work, Does/has anyone made a locking tab for a sidecover like a bolt or rivet or something, my side cover is good(talking bout left one) just locking tab is gone, I got zip ties on it now, seems almost impossible to get one sidecover that isnt broken there.
Side cover question
How "broken" is it? For me, only the very tip of the latch was gone, so I was able to re-build the latch with superglue and baking soda. Draketrumpet posted a pictorial of how he did the same thing. Just a drop of superglue at a time, then a dusting of baking soda (blow off the extra baking soda each time). Repeat over and over until you have a glob large enough to replace the broken piece. The superglue hardens almost instantly! Then just grind/sand the glob until you have the shape of the original latch, and it's SUPER strong!1980 XS850SG - Sold
-H. Ford -
I fixed mine by fabricating an alloy L bracket and bolting it the latch and the cover, but then i had all the pieces to begin with. Not quite so easy if your missing a bit1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
-H. FordComment
Craig - if it's just the tab on the side cover, I've got some stuff called Plastex that can fix it. It's got a little 'molding bar' that you heat up with a heat gun, and form it around a good part (which we have access to). You let it cool, and use it to form the new part on the bad piece. Takes about 20 minutes and fixes stuff like new. It's slicker than a cucumber in a woman's prison.
'79 XS11 Standard, Jardine 4/1, Dyna DC1-1 Coils, 145 mains, 45 pilots, plastic floats - 25.7mm, XV920 fuel valves, inline fuel filters, speed bleeders, Mikes XS pods, spade-type fuse block, fork brace, progressive fork springs/shocks, manual petcocks, 750 FD, Venture cam chain tensioner, SS brake linesComment
If you can get it over here by Kings Island, I'll fix it for you. Or you could order a Plastex kit, and do it yourself. I think the mini master kit is the one I've got. Looks like the price has come down too.Last edited by dbeardslee; 05-19-2010, 01:54 PM.I think I have a loose screw behind the handlebars.
The old gray biker ain't what he used to be.Comment
