I found that the rattle that I have been hearing on the 78 was the cam chain. I removed the valve cover and found an extrimly (I was able to lift it about one inch) loose chain. It was bunched up between the two sprockets ( it has jumped a couple of teeth) One of the cams is way off and I don't know wich one.
Here are some pictures of the state that its in (besides Utah)
What would be the best way to proceed?
I have turned the engine over clock wise but it felt like it hit a valve so I didn't force it.
Looks like I need to remoce the cams to get it back to where it needs to be. I can get to two of the bolts on the sprokets.
Can I turn it counter clock wise to get to the other two?
Will this hurt anything?
I'm hoping that I don't have a bent valve already
I do have a manual but they assume that everything is lined up correctly.
Any advice would be appreciated
