There are two bearings in the rear wheel, one is a normal wheel bearing. The other is a longer needle bearing and is very very difficult if not impossible to find.
As Tod mentioned, Randy has located a source for bulk supply, he occasionally orders a bunch and resells to members for basically cost. I believe he has sold all of the last batch.
Verify which you are after and if it is the tougher one to get, you can post here and hope someone has one to spare.
Member RS Thornton had found a new supplier about the time Randy sold the last of his order last time.
You might try and contact him to see if he still has a line on those bearings.
